    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 76.1k Views 40 Watching
    • KrisidiousK Offline
      Krisidious
      does this mean it's time for the Icon Making Challenge?
      By: Kristoff Rand
        LewisEE
        I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
          driven
          how did miss this one, very nice...
          just pondering some additional behaviour...
          I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
          I try to do it on my own plugins as well so the 'command' is the loader...
          example
                command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
          could the 'burying' be an option for this plugin?
          so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
          I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
          • alsomarA Offline
            alsomar Extension Creator
            Thank you so much Aerilius!
            It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
            Greetings!
            Alejandro Soriano Visuals · All my links
              Aerilius
              The toolbars are stored in the registry
              HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
              You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
              From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
              • alsomarA Offline
                Thank you for your response! Greetings! 😄
                  Lushi
                  i would love this tool could create groups of nested buttons, like those in the bar "getting started"
                  http://sketchucation.com/images/news/sketchup-2014-review/sketchup-2014-review-007.png
                    Aerilius
                    I would love this too!
                    But they are neither user-editable nor available for plugins.
                      glro
                      i can't enter snippets either
                      su8, win7
                        Aerilius
                        What happens when you can't enter snippets? What do you do and what does not happen?
                          glro
                          nothing happens...
                          after i fill in the form (name, category, ...), and i choose a file for the icon, it is then impossible for me to type anything in the area below the icon file address
                            Aerilius
                            I cannot reproduce this. For me the webdialog accepts input in all input fields in SU 2014, SU 2013, SU8, WinXP, Win7.
                            • What version of Internet Explorer do you have installed?
                            • Does the text area for Ruby code never accept input or only after you selected an icon?
                            • Can you see that it is a text area (or is it possible that it just has a zero size)?
                              glro
                              internet explorer 11
                              never accepts input
                              cannot see that it is a text area (screen copy added)add a button window
                              hope it helps
                                Jim
                                Same here - no input area for code.
                                Win 8.1, SU-2014 Pro, IE 11 (never used outside of SketchUp.)
                                  titou
                                  me too, same problem, cannot whrite anything in the text zone
                                    Jim
                                    I know it has probably already been thought about, but it would be incredible to have a command repository where we can browse, install, and share commands...
                                    Maybe a dvcs repo (github) could be used as the repo. What format would be good for command files - json or yaml maybe?
                                      Aerilius
                                      I uploaded a workaround for IE 11's bug (ToolbarEditor 1.1.2).
                                      Currently the plugin writes each snippet to a ruby file (in %APPDATA%) and stores the metadata with the plugin's preferences in the registry.
                                      A json or yaml format would also not be a bad idea. I chose rb because it contains runnable code and I don't need to extract the code from a part of the file (or deal with escaping etc.). The metadata is also written in the comment of the ruby file, but I haven't decided yet to parse it out of the comment again, because there would be many sources of error (or the comment would have to strictly follow a specific syntax.
                                        Jim
                                        Is the numeric part of the filename unique for each user? If so, that makes it difficult to have a way to share commands.
                                          glro
                                          another detail: the toolbar position is not stored when you close sketchup
                                          so you have to move it everytime you open
                                          not really important, but would it be possible to dck the created toolbars as the other native toolbars?
                                            Aerilius
                                            Plugins can not influence the position of the toolbar (they can only tell SketchUp to show/hide a toolbar, and Sketchup remembers the position). Since these toolbars are created with a timeout (after all other plugins have been loaded), there was initially a problem wher the toolbar didn't remember its position. After report it was improved in SU2013 so that SketchUp should remember the position even after timeout. In which SketchUp version does it happen to you?
                                            I have reduced the timeout, maybe that caused the problem?
                                            • 5 / 7
