    SU 2014 section cut shadow bug
    13 Posts 6 Posters 3.0k Views 6 Watching
      See it here too
      • KrisidiousK
        Krisidious
        That's ground level isn't it? I can't tell as the file is 14 and I don't have that.
        By: Kristoff Rand
        • K
          kaas
          It's not ground level. The ghosted shadows are visible only when there's geometry behind it. With just the background behind the ghost - it's gone.
          I can't reproduce it in SU2013 so must be new.
            I see it too in your model. That is weird.
              I see it too - PC v2014.
              The geometry above the section_plane appears to be casting weird shadows on what's visible below it...
              However if I purge unused in Model > Statistics the issue stops.
              BUT if I only purge the unused Components it does not.
              You have three materials called '$Irr Cache', '$Light Sprite' and 'glas'.
              If I purge those [now unused] the issue stops, suggesting it related to the materials messing with the SKP's data-base - although 'fix_issues' does nothing !
              Very oddly... if leave the unused components in the SKP... but I 'Delete' any one of those three materials from the Materials Browser, that fixes the issue.
              Deleting any one of them resolves it - as if something in the Materials data-base is foobar !
              A non-destructive solution [in case you want to use the components/materials later on] is to add a new material to the Model with the Material Browser's '+' button - this immediately fixes the phantom-shadow issue [ πŸ˜’ ], even when that new material is unused - then you can just Delete that unwanted material from the Materials Browser - the fix is not reversed by that. This 'material-add' seems to jolt the Model's Material data-base into normality, which in turn stops the phantom-shadow issue πŸ˜•
              It is VERY weird !
                Good catch, TIG. Editing one of the materials in an external editor seems to fix it as well.
                • K
                  kaas
                  It is VERY weird !
                  Thank for your reply TIG. '$Irr Cache', '$Light Sprite' are materials created by LightUp every time I open a file in SketchUp.
                  I tried your suggestions but they only seem to temporary 'fix' the problem.
                  1. Purge all materials so only the default material is left: after a few scene changes, it's back
                  2. create a new material. At that moment it's 'fixed' but after a few scene changes it's back.
                  very strange...indeed.
                  • tt_suT
                    tt_su
                    What are your graphic cards? Does it happen with Hardware Acceleration turned off?
                      Nvidia GTX680 here. It does show with Hardware Acceleration turned off.
                      • tt_suT
                        tt_su
                        Thanks. It has been reproduced internally and logged.
                        • tt_suT
                          tt_su
                          Update: Workaround: enable scene transition.
                          • K
                            kaas
                            Great tip! especially with 0 seconds
