    SU 2014 section cut shadow bug
    13 Posts 6 Posters 2.6k Views 6 Watching
      kaas
      I just noticed a bug that sometimes happens in SU2014.
      Shadow artifacts appear when changing to scenes with a section cut while shadows are on. These scenes only have an 'active selection planes' property. If I rotate the 'bugged' view it seems like the part that's been cut off is ghosted.
      Once this happens, the only option is to toggle 'display section cuts' to 'fix' it. I tested the same file in SU2013 and I can't reproduce it there.
      I made a simple file to check if was a problem with my current project but I can reproduce it in the simple file (see attachment) as well. Just switch scenes several times and after a few times the ghosted shadows appear, very visible when rotating the view.
      sectionShadowArtifacts.skp
        See it here too
        • KrisidiousK Offline
          Krisidious
          That's ground level isn't it? I can't tell as the file is 14 and I don't have that.
          By: Kristoff Rand
            kaas
            It's not ground level. The ghosted shadows are visible only when there's geometry behind it. With just the background behind the ghost - it's gone.
            I can't reproduce it in SU2013 so must be new.
              I see it too in your model. That is weird.
                I see it too - PC v2014.
                The geometry above the section_plane appears to be casting weird shadows on what's visible below it...
                However if I purge unused in Model > Statistics the issue stops.
                BUT if I only purge the unused Components it does not.
                You have three materials called '$Irr Cache', '$Light Sprite' and 'glas'.
                If I purge those [now unused] the issue stops, suggesting it related to the materials messing with the SKP's data-base - although 'fix_issues' does nothing !
                Very oddly... if leave the unused components in the SKP... but I 'Delete' any one of those three materials from the Materials Browser, that fixes the issue.
                Deleting any one of them resolves it - as if something in the Materials data-base is foobar !
                A non-destructive solution [in case you want to use the components/materials later on] is to add a new material to the Model with the Material Browser's '+' button - this immediately fixes the phantom-shadow issue [ πŸ˜’ ], even when that new material is unused - then you can just Delete that unwanted material from the Materials Browser - the fix is not reversed by that. This 'material-add' seems to jolt the Model's Material data-base into normality, which in turn stops the phantom-shadow issue πŸ˜•
                It is VERY weird !
                  Good catch, TIG. Editing one of the materials in an external editor seems to fix it as well.
                    kaas
                    It is VERY weird !
                    Thank for your reply TIG. '$Irr Cache', '$Light Sprite' are materials created by LightUp every time I open a file in SketchUp.
                    I tried your suggestions but they only seem to temporary 'fix' the problem.
                    1. Purge all materials so only the default material is left: after a few scene changes, it's back
                    2. create a new material. At that moment it's 'fixed' but after a few scene changes it's back.
                    very strange...indeed.
                    • tt_suT Offline
                      tt_su
                      What are your graphic cards? Does it happen with Hardware Acceleration turned off?
                        Nvidia GTX680 here. It does show with Hardware Acceleration turned off.
                        • tt_suT Offline
                          tt_su
                          Thanks. It has been reproduced internally and logged.
                          • tt_suT Offline
                            tt_su
                            Update: Workaround: enable scene transition.
                              kaas
                              Great tip! especially with 0 seconds
