    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • fredo6F
      NEW RELEASE: JointPush Pull Interactive v3.2a - 25 Jan 14
      JointPushPull Interactive 3.2a includes a Projected mode for Vector Push-Pull (see video).
      [flash=425,344:3hd996ii]http://www.youtube.com/v/qsKZpmrJkxs&hl[/flash:3hd996ii]
      • cottyC
        cotty
        One WOW! per day, a good average ๐Ÿ˜‰
        ๐Ÿ‘
        my SketchUp gallery
        • CadFatherC
          CadFather
          wow indeed, here's a scary thought... ..imagine life without Fredo6..... ๐Ÿ˜ฒ ๐Ÿ˜†
          • B
            babak
            Happy new year and thank you very much !
              Hello Fredo
              Does it possible to keep a multiple selection result of a JPP for another "Joint Push Pull" ?
              CTRL seems don't working! ๐Ÿ˜•
              If not does exist a plugin for a "circular selection" ?
              Will be cool in this case (for select all vertical faces) and many other cases! ๐Ÿ˜„
              A general circular selection will be sufficient with the help of the Inverse Selection existing! ๐Ÿ˜‰
              On the right one result wanted...sor many other JPP are missing! ๐Ÿ˜„
              • N
                numerobis
                did you try to recall the last selection?
                http://sketchucation.com/pluginstore?pln=tt_selection_memory
                  No! I will try that! ๐Ÿ˜„
                  But Circular selection wiil be also a cool thing for another thing if possible! ๐Ÿ˜„
                    @numerobis
                    I have used the Thomthom Recall last selection but alas that can't work in this case because of course it's a new selection never yet selected! ๐Ÿ˜ฎ
                    • B
                      Ben Ritter
                      Fredo, thank you!!!!
                        Seems you can make something with the Taper function inside the plugin?
                        But seems you don't escape to make an intersection and some delete! ๐Ÿ˜ฒ
                        would love if anyone could give an alternate solution ๐Ÿ˜ƒ
                        if you have the Pro seems boolean solids Difference will be fine ?
                          And it's maybe more tricky to make a thickness with The JPP ! ๐Ÿ˜‰
                          You will obtain more easily that you want! ๐Ÿ˜„
                            Another thing to consider is that changing the order in which you do things might change the outcome. Pilou's second example shows that with his opening drawn before the wall is given thickness. An alternative might be as shown below.
                            Or maybe you break the thing down into a single copy of the repeating element and, once you've drawn it, copy that as needed.
                            • T
                              TechnoGuru
                              Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
                              Thanks CC
                                Thanks CC
                                You could try this thread: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17947 but you should really install the Sketchucation Plugin Store and auto-install plugins.
                                • B
                                  BruceG
                                  I've installed the latest version and still have no luck with the new joint push pull in Windows 8.1. The old joint push pull still functions. I have a similar problem with AMD 7700 video card with latest updated driver and the following installed
                                  extensions:SketchUcation
                                  3DxSketchUp
                                  BezierSpline
                                  Dialog
                                  Bulge
                                  Push
                                  Smooth
                                  Smudge
                                  Grab
                                  Planar Lock
                                  Arcs Circles
                                  Fredo6 LibFredo6
                                  Fredo6 Curviloft
                                  Fredo6 Curvizard
                                  Fredo6 FredoScale
                                  Fredo6 Fredo Tools
                                  Fredo6 JointPushPull
                                  Fredo6 Round Corner
                                  Fredo6 Tools on Surface
                                  JointPushPull
                                  quarr_jsalign
                                  s4u-AlignTool
                                  STL Import & Export
                                  CleanUpยณ
                                  TT_Libยฒ
                                  Edge Toolsยฒ
                                  Solid Inspector
                                  Any suggestions?
                                    You have the new AND old versions of JointPushPull listed.
                                    Disable the older one and restart and see if that helps.
                                    If so, then remove its .rb file permanently from the Plugins folder: it is not normally meant to load side by side with the newer 'Fredo...' version. ๐Ÿ˜•
                                    Incidentally, what exactly are these listed items ?
                                    Dialog Bulge Push Smooth Smudge Grab Planar Lock
                                    I assume you do mean Extensions rather than Plugins ?
                                    What does their description say ??
                                    Also giving us info in your SCF User Profile - about your OS and SketchUp version helps us help you ๐Ÿ˜’
                                    • fredo6F
                                      For info, the old and new versions of Joint Push Pull can safely coexist.
                                      And all my plugin are enabled as active extension by default and have their Toolbar visible by default at first installation.
                                      I think the problem comes from a wrong installation, and anyway should be clarified by BruceG. What is the problem exactly?
                                      • the plugin does not appear
                                      • There is an error message at startup of Sketchup
                                      • JPP 3.2 does crash or does nothing when launched,
                                      • etc...
                                      Without this information, it is difficult to assist.
                                        3dsmax9
                                        this tool is amazing i just wish if it is possibele to add the undo and redo botton like in the oldest version it wash mutch quicker tu redo the last action that way, and thanks for all your amazing plug in
                                        • fredo6F
                                          To Undo, you can freely use Ctrl-Z within the plugin, or click on the Orange backtrack Arrow in the button palette.
                                          To redo, select the faces you want to push-pull and just double click
                                          • panixiaP
                                            panixia
                                            404 Not Found
                                            (sketchucation.com)
                                            • 30
                                            • 31
                                            • 3 / 31
