    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.0k Views 155 Watching
    • N
      numerobis
      did you try to recall the last selection?
      http://sketchucation.com/pluginstore?pln=tt_selection_memory
        No! I will try that! ๐Ÿ˜„
        But Circular selection wiil be also a cool thing for another thing if possible! ๐Ÿ˜„
          @numerobis
          I have used the Thomthom Recall last selection but alas that can't work in this case because of course it's a new selection never yet selected! ๐Ÿ˜ฎ
          • B
            Ben Ritter
            Fredo, thank you!!!!
              Seems you can make something with the Taper function inside the plugin?
              But seems you don't escape to make an intersection and some delete! ๐Ÿ˜ฒ
              would love if anyone could give an alternate solution ๐Ÿ˜ƒ
              if you have the Pro seems boolean solids Difference will be fine ?
                And it's maybe more tricky to make a thickness with The JPP ! ๐Ÿ˜‰
                You will obtain more easily that you want! ๐Ÿ˜„
                  Another thing to consider is that changing the order in which you do things might change the outcome. Pilou's second example shows that with his opening drawn before the wall is given thickness. An alternative might be as shown below.
                  Or maybe you break the thing down into a single copy of the repeating element and, once you've drawn it, copy that as needed.
                  • T
                    TechnoGuru
                    Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
                    Thanks CC
                      Thanks CC
                      You could try this thread: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17947 but you should really install the Sketchucation Plugin Store and auto-install plugins.
                      • B
                        BruceG
                        I've installed the latest version and still have no luck with the new joint push pull in Windows 8.1. The old joint push pull still functions. I have a similar problem with AMD 7700 video card with latest updated driver and the following installed
                        extensions:SketchUcation
                        3DxSketchUp
                        BezierSpline
                        Dialog
                        Bulge
                        Push
                        Smooth
                        Smudge
                        Grab
                        Planar Lock
                        Arcs Circles
                        Fredo6 LibFredo6
                        Fredo6 Curviloft
                        Fredo6 Curvizard
                        Fredo6 FredoScale
                        Fredo6 Fredo Tools
                        Fredo6 JointPushPull
                        Fredo6 Round Corner
                        Fredo6 Tools on Surface
                        JointPushPull
                        quarr_jsalign
                        s4u-AlignTool
                        STL Import & Export
                        CleanUpยณ
                        TT_Libยฒ
                        Edge Toolsยฒ
                        Solid Inspector
                        Any suggestions?
                          You have the new AND old versions of JointPushPull listed.
                          Disable the older one and restart and see if that helps.
                          If so, then remove its .rb file permanently from the Plugins folder: it is not normally meant to load side by side with the newer 'Fredo...' version. ๐Ÿ˜•
                          Incidentally, what exactly are these listed items ?
                          Dialog Bulge Push Smooth Smudge Grab Planar Lock
                          I assume you do mean Extensions rather than Plugins ?
                          What does their description say ??
                          Also giving us info in your SCF User Profile - about your OS and SketchUp version helps us help you ๐Ÿ˜’
                          • fredo6F
                            For info, the old and new versions of Joint Push Pull can safely coexist.
                            And all my plugin are enabled as active extension by default and have their Toolbar visible by default at first installation.
                            I think the problem comes from a wrong installation, and anyway should be clarified by BruceG. What is the problem exactly?
                            • the plugin does not appear
                            • There is an error message at startup of Sketchup
                            • JPP 3.2 does crash or does nothing when launched,
                            • etc...
                            Without this information, it is difficult to assist.
                              3dsmax9
                              this tool is amazing i just wish if it is possibele to add the undo and redo botton like in the oldest version it wash mutch quicker tu redo the last action that way, and thanks for all your amazing plug in
                              • fredo6F
                                To Undo, you can freely use Ctrl-Z within the plugin, or click on the Orange backtrack Arrow in the button palette.
                                To redo, select the faces you want to push-pull and just double click
                                • panixiaP
                                  panixia
                                  404 Not Found
                                  (sketchucation.com)
                                    David.P
                                    As a brand new user to Fredo's tools I am sure that this is all incredibly amazing.
                                    Only thing is that the GUI looks garbled on pretty much anything other than the standard DPI settings of Windows (which is much too low for nowadays high resolution screens):
                                    http://666kb.com/i/cm74vc86gocwgwb5h.png
                                    This is with Windows screen DPI set to 125%.
                                    Anyway, keep up the great work
                                    Regards David.P
                                      Except the basic but robust graphic aspect does the functions are good working ? ๐Ÿ˜‰
                                        David.P
                                        Honestly, the obvious abundance of functions has frightend me off so far -- all the more since (additionally) I can't really seem to read what everything does. It's stupid I know, but maybe it is only decades of bad experience with garbled UI's that puts me off to even try and touch these tools.
                                          Sure, it's a program inside program but..take your time to experiment! ๐Ÿ˜‰
                                          Maybe there is inside the function that you have always dreamed! โ˜€
                                          • U
                                            unearthed
                                            Agree with Pilou 100% - the plugin writers on here are coming from dozens of different design backgrounds and cultures - so you can expect some individuality in interfaces (and some unique and different approaches to problems), and fredo's tools are great tools - out of all the tools I suggest you start on something like vector or normal (multi-face push-pull) they're pretty amazing all on their own, some serious time savers here.
                                            Growplan - People โˆฉ Plants โˆฉ Place
                                            windows 7 64b, 4GB RAM, SU 8.0.16846
                                            Gimp, QGIS, Vectorworks 12, Bricscad 11
                                            • 30
                                            • 31
                                            • 3 / 31
