    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 887.3k Views 155 Watching
    • cottyC Offline
      cotty
      You should never use special characters in path names!
      in your case: '13...
      my SketchUp gallery
        Certainly special characters like รฉ or รถ will break the current version of Ruby that ships with SketchUp.
        The ' is a special case, because it breaks some Ruby and js when passed in a string that is 'raw'.
        The author can use " " to encapsulate Ruby string parts so the included ' is preserved.
        Or if the encapsulation is ' ' it must then be escaped - tr("'","'") for js use it's best perhaps as say tr("'","\\'") ...
        But for now please leave ' out of your path-names - there are many alternatives... ๐Ÿ˜’
        • N Offline
          numerobis
          Almost two months online already... How could i miss this one?!? ๐Ÿ˜ฎ
          Unbelievable! You've done it again... Great improvement! ๐Ÿ˜Ž
          I'm not sure if the sketchup "developers" are still following what's going on with their software on plugin level... If i would be in their position i would really be ashamed...
          • E Offline
            Elmer BeFuddled
            Right, I shall remove the offending "happy oz trophy" (which is a straight one, nothing oblique or fancy) from the SU file path.
            Its never affected any thing else when I abb. (tee hee!! ๐Ÿ˜‰ ) the date in the path name but I'll be honest, up until ten days ago I'd never heard of Ruby, heathen that I am!!
            A thought. A.N.Other plug-in, the SVG importer that required rexml (from Ruby) to be added into the plug-ins folder didn't work either, though I can't remember the error msg. I received.
            It may also be why I can't import *.dxf files from Inkscape that were made from a *.pdf files that were made in Photoshop from *.psd files that were made from thoughts in my single malt, whisky hazed mind!
            Back to the point, I'll update you with as to how things went.
            !!! HOT OFF THE PRESSES !!!
            An Update.
            Well, I re-installed SU to C:\Program Files (x86)\DEVELOP\SketchUp 13 and Ruby to C:\Program Files (x86)\DEVELOP\Ruby193 and voila!! Joint Push Pull and Tools on Surface both popped up their toolbars when I opened up SU.
            Who'd have thunked a little apostrophe could cause so much hassle!
            That would never of crossed my mind as I've been 'apostrophising' install paths and file names since Jesus left Kilmarnock (a.k.a a very long time) with no issues. Strange how the parenthesis as in (x86) get ignored!
            Still having problems with the svg importer (the error message shows one oblique and one straight comma) but I'll post about that in the correct place.
            Many many thanks to you cotty and TIG for your help. I'd have got nowhere without it.
            ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
            Elmer
            • fredo6F Offline
              NEW RELEASE: JointPush Pull Interactive v3.2a - 25 Jan 14
              JointPushPull Interactive 3.2a includes a Projected mode for Vector Push-Pull (see video).
              [flash=425,344:3hd996ii]http://www.youtube.com/v/qsKZpmrJkxs&hl[/flash:3hd996ii]
              • cottyC Offline
                cotty
                One WOW! per day, a good average ๐Ÿ˜‰
                ๐Ÿ‘
                my SketchUp gallery
                • CadFatherC Offline
                  CadFather
                  wow indeed, here's a scary thought... ..imagine life without Fredo6..... ๐Ÿ˜ฒ ๐Ÿ˜†
                    babak
                    Happy new year and thank you very much !
                      Hello Fredo
                      Does it possible to keep a multiple selection result of a JPP for another "Joint Push Pull" ?
                      CTRL seems don't working! ๐Ÿ˜•
                      If not does exist a plugin for a "circular selection" ?
                      Will be cool in this case (for select all vertical faces) and many other cases! ๐Ÿ˜„
                      A general circular selection will be sufficient with the help of the Inverse Selection existing! ๐Ÿ˜‰
                      On the right one result wanted...sor many other JPP are missing! ๐Ÿ˜„
                      • N Offline
                        numerobis
                        did you try to recall the last selection?
                        http://sketchucation.com/pluginstore?pln=tt_selection_memory
                          No! I will try that! ๐Ÿ˜„
                          But Circular selection wiil be also a cool thing for another thing if possible! ๐Ÿ˜„
                            @numerobis
                            I have used the Thomthom Recall last selection but alas that can't work in this case because of course it's a new selection never yet selected! ๐Ÿ˜ฎ
                              Ben Ritter
                              Fredo, thank you!!!!
                                Seems you can make something with the Taper function inside the plugin?
                                But seems you don't escape to make an intersection and some delete! ๐Ÿ˜ฒ
                                would love if anyone could give an alternate solution ๐Ÿ˜ƒ
                                if you have the Pro seems boolean solids Difference will be fine ?
                                  And it's maybe more tricky to make a thickness with The JPP ! ๐Ÿ˜‰
                                  You will obtain more easily that you want! ๐Ÿ˜„
                                    Another thing to consider is that changing the order in which you do things might change the outcome. Pilou's second example shows that with his opening drawn before the wall is given thickness. An alternative might be as shown below.
                                    Or maybe you break the thing down into a single copy of the repeating element and, once you've drawn it, copy that as needed.
                                      TechnoGuru
                                      Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
                                      Thanks CC
                                        Thanks CC
                                        You could try this thread: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17947 but you should really install the Sketchucation Plugin Store and auto-install plugins.
                                          BruceG
                                          I've installed the latest version and still have no luck with the new joint push pull in Windows 8.1. The old joint push pull still functions. I have a similar problem with AMD 7700 video card with latest updated driver and the following installed
                                          extensions:SketchUcation
                                          3DxSketchUp
                                          BezierSpline
                                          Dialog
                                          Bulge
                                          Push
                                          Smooth
                                          Smudge
                                          Grab
                                          Planar Lock
                                          Arcs Circles
                                          Fredo6 LibFredo6
                                          Fredo6 Curviloft
                                          Fredo6 Curvizard
                                          Fredo6 FredoScale
                                          Fredo6 Fredo Tools
                                          Fredo6 JointPushPull
                                          Fredo6 Round Corner
                                          Fredo6 Tools on Surface
                                          JointPushPull
                                          quarr_jsalign
                                          s4u-AlignTool
                                          STL Import & Export
                                          CleanUpยณ
                                          TT_Libยฒ
                                          Edge Toolsยฒ
                                          Solid Inspector
                                          Any suggestions?
                                            You have the new AND old versions of JointPushPull listed.
                                            Disable the older one and restart and see if that helps.
                                            If so, then remove its .rb file permanently from the Plugins folder: it is not normally meant to load side by side with the newer 'Fredo...' version. ๐Ÿ˜•
                                            Incidentally, what exactly are these listed items ?
                                            Dialog Bulge Push Smooth Smudge Grab Planar Lock
                                            I assume you do mean Extensions rather than Plugins ?
                                            What does their description say ??
                                            Also giving us info in your SCF User Profile - about your OS and SketchUp version helps us help you ๐Ÿ˜’
                                            • 30
                                            • 31
                                            • 3 / 31
