    Camera totally lost, ans Zoom Extents doesn't help
    19 Posts 6 Posters 2.0k Views 6 Watching
      ManuHeel
      Yeah, I don't know what happened ><
      Don't bother, the piano is the only thing I can rebuild without problem, as I have the measures.
        m=Sketchup.active_model #<Sketchup::Model:0x5ae8378> bb=m.bounds #<Geom::BoundingBox:0x88ce15c> bb.min Point3d(-3.06746, 0, -1.1692e+049) bb.max Point3d(53.2677, 9.35361e+049, 12.0827)
        Clearly something nasty is a zillion miles away πŸ˜’
        Those values are astronomical !
          Ah ha! It is the distant geometry thing.
            At 9.35361e+049 inches
            Something is @
            1,476,264,204,545,454,550,000,000,000,000,000,000,000,000,000 miles
            from the origin !
            OR
            ~25,112,920,5364,175,316,000,000,000,000,000,000 light-years
            which is a LOT more than the diameter of the Milky Way Galaxy @
            ~120,000 light-years
            OR the observable Universe itself @
            ~93,000,000,000 light-years
            πŸ˜’
            However, if you Select All, get the Component and then Explode it etc... then query the Edges in the model [there are only Faces and Edges in it] - for 'small' and 'large' we get this:
            Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e| p e.length.to_mm if e.length < 0.25.mm || e.length > 1500.mm} 0.0639867005970645 0.0639867005970814
            The very tiny edges could cause issues but this suggests that some of them are simply far far away ?
            This code finds just one culprit:
            Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|p e.bounds.max if e.bounds.max.y > 10.m} Point3d(0.19685, 9.35361e+049, -1e+030)
            So we can delete it thus:
            Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|e.erase! if e.bounds.max.y > 10.m}
            Then a Zoom-extents works... and all is well again ! 😍
            A v8 of the fixed SKP is attached... πŸ˜„
            Buggy Piano Component.skp
              That has to set a record for most distant geometry in SketchUp.
              • BoxB
                Did you find a talking donkey at far far away.
                  ManuHeel
                  Woah, thanks TIG.
                  Next time I'll try not to destroy the space-time continuum πŸ˜„
                  • ely862meE
                    ely862me
                    I believe Tig has just discovered a way to reduce the time of the light-year travel ! πŸ˜„
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • cottyC
                      cotty
                      I'm looking forward to the day he implements this technique in his plugins to increase their speed πŸ˜„
                      my SketchUp gallery
                      • ely862meE
                        ely862me
                        I believe that are not his plugins that are not up to speed, but the universe we use them in .
