    Camera totally lost, ans Zoom Extents doesn't help
    19 Posts 6 Posters 1.6k Views 6 Watching
      Is it possible you've got some little line segment or something at a long distance from the origin? When you hit Zoom Extents, where on the screen does the origin display?
      Posting the SKP file would be helpful.
        @manuheel said:
        If I select all, it says that i selected 7 entities, which are my 7 components in the model.
        I can share it if this can help.
        I don't know where to found layers, styles, model statistics, outliner, sorry -_-'
        EDIT : Found them, and my components are here, but can't be displayed πŸ˜•
        Why not ?
        Have you used Model Info > Statistic > Fix problems ?
        Are all Layers ON ?
        Is View > Hidden Geometry ON ?
        Are Guides set ON ?
        If you Zoom-extents what happens ?
        If you activate a Scene-tab what happens ?
        If you export the Model's Components [7] to a Collection and then edit each one of those SKPs in turn, fixing issues etc and erasing guides/points, and any rogue geometry far far from the origin etc... what happens ?
        Reload the Components one at a time into the problem SKP and see what happens ?
        Load the Components one at a time into an empty SKP and see what happens ?
          ManuHeel
          @Dave :
          I was moving a part when this happened so maybe it went 10000000 miles away, so yes.
          Zoom Extents get the origin (when I manage to get it) to the left middle.
          I can't post the file, it's 5.7 Mio and I can't post over 4 Mio
          @TIG
          Everything is on, but I'll try to add the components in an empty SKP
            ManuHeel
            Okay, I found the component which was causing trouble.
            I was adding the black notes to my piano model and I think a black note is causing trouble.
            Adding this particular component gives me the problem.
            If you can find a way to fix it, here is the model, if not, it's not that bad as I got my other components back.
            Buggy Piano Component
              It looks to me as if you deleted all the geometry in the component while it was open for editing. That'll certainly cause you problems. I guess I'd start over.
              • cottyC Offline
                cotty
                If you edit the piano component and select all entities, there are 826 entities:
                If you use the position camera tool, you get this eye height:
                πŸ˜•
                my SketchUp gallery
                  ManuHeel
                  Yeah, I don't know what happened ><
                  Don't bother, the piano is the only thing I can rebuild without problem, as I have the measures.
                    m=Sketchup.active_model #<Sketchup::Model:0x5ae8378> bb=m.bounds #<Geom::BoundingBox:0x88ce15c> bb.min Point3d(-3.06746, 0, -1.1692e+049) bb.max Point3d(53.2677, 9.35361e+049, 12.0827)
                    Clearly something nasty is a zillion miles away πŸ˜’
                    Those values are astronomical !
                      Ah ha! It is the distant geometry thing.
                        At 9.35361e+049 inches
                        Something is @
                        1,476,264,204,545,454,550,000,000,000,000,000,000,000,000,000 miles
                        from the origin !
                        OR
                        ~25,112,920,5364,175,316,000,000,000,000,000,000 light-years
                        which is a LOT more than the diameter of the Milky Way Galaxy @
                        ~120,000 light-years
                        OR the observable Universe itself @
                        ~93,000,000,000 light-years
                        πŸ˜’
                        However, if you Select All, get the Component and then Explode it etc... then query the Edges in the model [there are only Faces and Edges in it] - for 'small' and 'large' we get this:
                        Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e| p e.length.to_mm if e.length < 0.25.mm || e.length > 1500.mm} 0.0639867005970645 0.0639867005970814
                        The very tiny edges could cause issues but this suggests that some of them are simply far far away ?
                        This code finds just one culprit:
                        Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|p e.bounds.max if e.bounds.max.y > 10.m} Point3d(0.19685, 9.35361e+049, -1e+030)
                        So we can delete it thus:
                        Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|e.erase! if e.bounds.max.y > 10.m}
                        Then a Zoom-extents works... and all is well again ! 😍
                        A v8 of the fixed SKP is attached... πŸ˜„
                        Buggy Piano Component.skp
                          That has to set a record for most distant geometry in SketchUp.
                          • BoxB Offline
                            Did you find a talking donkey at far far away.
                              ManuHeel
                              Woah, thanks TIG.
                              Next time I'll try not to destroy the space-time continuum πŸ˜„
                              • ely862meE Offline
                                ely862me
                                I believe Tig has just discovered a way to reduce the time of the light-year travel ! πŸ˜„
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • cottyC Offline
                                  cotty
                                  I'm looking forward to the day he implements this technique in his plugins to increase their speed πŸ˜„
                                  my SketchUp gallery
                                  • ely862meE Offline
                                    ely862me
                                    I believe that are not his plugins that are not up to speed, but the universe we use them in .
