    Camera totally lost, ans Zoom Extents doesn't help
    19 Posts 6 Posters 1.9k Views 6 Watching
      It looks to me as if you deleted all the geometry in the component while it was open for editing. That'll certainly cause you problems. I guess I'd start over.
      • cottyC
        cotty
        If you edit the piano component and select all entities, there are 826 entities:
        If you use the position camera tool, you get this eye height:
        πŸ˜•
        my SketchUp gallery
          ManuHeel
          Yeah, I don't know what happened ><
          Don't bother, the piano is the only thing I can rebuild without problem, as I have the measures.
            m=Sketchup.active_model #<Sketchup::Model:0x5ae8378> bb=m.bounds #<Geom::BoundingBox:0x88ce15c> bb.min Point3d(-3.06746, 0, -1.1692e+049) bb.max Point3d(53.2677, 9.35361e+049, 12.0827)
            Clearly something nasty is a zillion miles away πŸ˜’
            Those values are astronomical !
              Ah ha! It is the distant geometry thing.
                At 9.35361e+049 inches
                Something is @
                1,476,264,204,545,454,550,000,000,000,000,000,000,000,000,000 miles
                from the origin !
                OR
                ~25,112,920,5364,175,316,000,000,000,000,000,000 light-years
                which is a LOT more than the diameter of the Milky Way Galaxy @
                ~120,000 light-years
                OR the observable Universe itself @
                ~93,000,000,000 light-years
                πŸ˜’
                However, if you Select All, get the Component and then Explode it etc... then query the Edges in the model [there are only Faces and Edges in it] - for 'small' and 'large' we get this:
                Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e| p e.length.to_mm if e.length < 0.25.mm || e.length > 1500.mm} 0.0639867005970645 0.0639867005970814
                The very tiny edges could cause issues but this suggests that some of them are simply far far away ?
                This code finds just one culprit:
                Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|p e.bounds.max if e.bounds.max.y > 10.m} Point3d(0.19685, 9.35361e+049, -1e+030)
                So we can delete it thus:
                Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|e.erase! if e.bounds.max.y > 10.m}
                Then a Zoom-extents works... and all is well again ! 😍
                A v8 of the fixed SKP is attached... πŸ˜„
                Buggy Piano Component.skp
                  That has to set a record for most distant geometry in SketchUp.
                  • BoxB
                    Did you find a talking donkey at far far away.
                      ManuHeel
                      Woah, thanks TIG.
                      Next time I'll try not to destroy the space-time continuum πŸ˜„
                      • ely862meE
                        ely862me
                        I believe Tig has just discovered a way to reduce the time of the light-year travel ! πŸ˜„
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • cottyC
                          cotty
                          I'm looking forward to the day he implements this technique in his plugins to increase their speed πŸ˜„
                          my SketchUp gallery
                          • ely862meE
                            ely862me
                            I believe that are not his plugins that are not up to speed, but the universe we use them in .
