    Camera totally lost, ans Zoom Extents doesn't help
    19 Posts 6 Posters 2.0k Views 6 Watching
      ManuHeel
      @Dave :
      I was moving a part when this happened so maybe it went 10000000 miles away, so yes.
      Zoom Extents get the origin (when I manage to get it) to the left middle.
      I can't post the file, it's 5.7 Mio and I can't post over 4 Mio
      @TIG
      Everything is on, but I'll try to add the components in an empty SKP
        ManuHeel
        Okay, I found the component which was causing trouble.
        I was adding the black notes to my piano model and I think a black note is causing trouble.
        Adding this particular component gives me the problem.
        If you can find a way to fix it, here is the model, if not, it's not that bad as I got my other components back.
        Buggy Piano Component
          It looks to me as if you deleted all the geometry in the component while it was open for editing. That'll certainly cause you problems. I guess I'd start over.
          • cottyC
            cotty
            If you edit the piano component and select all entities, there are 826 entities:
            If you use the position camera tool, you get this eye height:
            πŸ˜•
            my SketchUp gallery
              ManuHeel
              Yeah, I don't know what happened ><
              Don't bother, the piano is the only thing I can rebuild without problem, as I have the measures.
                m=Sketchup.active_model #<Sketchup::Model:0x5ae8378> bb=m.bounds #<Geom::BoundingBox:0x88ce15c> bb.min Point3d(-3.06746, 0, -1.1692e+049) bb.max Point3d(53.2677, 9.35361e+049, 12.0827)
                Clearly something nasty is a zillion miles away πŸ˜’
                Those values are astronomical !
                  Ah ha! It is the distant geometry thing.
                    At 9.35361e+049 inches
                    Something is @
                    1,476,264,204,545,454,550,000,000,000,000,000,000,000,000,000 miles
                    from the origin !
                    OR
                    ~25,112,920,5364,175,316,000,000,000,000,000,000 light-years
                    which is a LOT more than the diameter of the Milky Way Galaxy @
                    ~120,000 light-years
                    OR the observable Universe itself @
                    ~93,000,000,000 light-years
                    πŸ˜’
                    However, if you Select All, get the Component and then Explode it etc... then query the Edges in the model [there are only Faces and Edges in it] - for 'small' and 'large' we get this:
                    Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e| p e.length.to_mm if e.length < 0.25.mm || e.length > 1500.mm} 0.0639867005970645 0.0639867005970814
                    The very tiny edges could cause issues but this suggests that some of them are simply far far away ?
                    This code finds just one culprit:
                    Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|p e.bounds.max if e.bounds.max.y > 10.m} Point3d(0.19685, 9.35361e+049, -1e+030)
                    So we can delete it thus:
                    Sketchup.active_model.entities.grep(Sketchup::Edge).each{|e|e.erase! if e.bounds.max.y > 10.m}
                    Then a Zoom-extents works... and all is well again ! 😍
                    A v8 of the fixed SKP is attached... πŸ˜„
                    Buggy Piano Component.skp
                      That has to set a record for most distant geometry in SketchUp.
                      • BoxB
                        Did you find a talking donkey at far far away.
                          ManuHeel
                          Woah, thanks TIG.
                          Next time I'll try not to destroy the space-time continuum πŸ˜„
                          • ely862meE
                            ely862me
                            I believe Tig has just discovered a way to reduce the time of the light-year travel ! πŸ˜„
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • cottyC
                              cotty
                              I'm looking forward to the day he implements this technique in his plugins to increase their speed πŸ˜„
                              my SketchUp gallery
                              • ely862meE
                                ely862me
                                I believe that are not his plugins that are not up to speed, but the universe we use them in .
