    2013 crashes everytime i use fredo6's bz tools?
    34 Posts 13 Posters 4.1k Views 13 Watching
      digitecture
      @dave r said:
      Please update your profile to include your OS and SU version.
      There are permission settings for the Plugins folder on Mac OSX, at least the most recent two versions.
      Did you update the entire LibFredo6 files? You didn't say.
      Yes, I am using the Sketchucation plugin store to manage plugins so I update from there.
      I updated the Fredo libs, and the plugin to the newest that is available from there.
      What should the permissions be set to other than for my user read and write, fetching read only, and everyone read only?
      BTW - I just autoinstalled again all of Fredo's plugins that I use from Sketchucation plugin store. Most are updated from April 2013 which is before the release of SU 2013.
        I would set your Plugins folder's permissions to be FULL read/write for everyone ?
        Fredo updated some of his tools before to the release of v2013 - in anticipation of its impending changes...
        The Fredo tools' files AND FredoLib etc at the SCF PluginStore are all the latest versions, and will work with v2013 and earlier too...
        Note that v2013 uses a different default Plugins folder location to v8 - are you doing this right?
        You should have FULL permissions to it as it's now in your personal 'users-path'
        What does this code return for you - Ruby Console copy/paste+<enter>:
        Sketchup.find_support_file('plugins')
          digitecture
          I know where the 2013 plugins are located.
          /Users/xxxx/Library/Application Support/SketchUp 2013/SketchUp/plugins
          When I look at the info for the plugins folder it is set to ready and write for everyone but when I look at individual plugin folders within that folder these are not set to that. Do I have to set each file and folder to this?
          -Okay, I applied those settings to all enclosed items.
          This should be done when Sketchup installs. Does everyone do this when they upgrade to the next version?
            I only needed to set permissions for the Plugins folder. I have had no reason to touch any of the folders inside of that folder. Perhaps if you had set the permissions for the folder up front before adding the plugins to it, you wouldn't have had any problems.
              digitecture
              The problem is unless you have encountered this problem, the general user would never know about this.
              This is the first time, I have had SketchUp crash like this that required a search for an answer.
                I'm not scolding. It's true, you wouldn't.
                On the other hand, a huge number of the posts in the original thread for the plugin cover this exact problem. This also shows threads for a number of other plugins. So the information is available. Fredo's RoundCorner plugin thread makes it clear in the first few lines. Maybe he could add that comment to his other threads as well.
                • G
                  gigi500
                  Was there a solution? I have the same problem, Mac 2013pro, permissions, etc, reloaded - still crashes....The only plug in that does...Fredo6's loft tools do not, so I have an updated library, etc
                  • C
                    castromann
                    Same question?
                    Also on mac ML with Sketchup 2013. BZ tools crash every time.
                    I went through all the suggestion in this and the plugin thread and unfortunately nothing helped.
                    • fredo6F
                      @castromann said:
                      Same question?
                      Do you get a crash too with my other plugins (like FredoScale, RoundCorner, ...)?
                      • C
                        castromann
                        no, not at all. everything else works perfectly fine.
                        • EdsonE
                          Edson
                          I have the same problem in one of my 3 machines. they all run Mountain Lion, the latest SU and the latest Fredo plugins, but the crashes occur in only one of them.
                          http://www.mahfuz.arq.br
                          • fredo6F
                            What would be helpful is that you describe the context of the crash
                            • at startup or when drawing or when generating or when modifying
                            • which tool or all tools
                            • etc....
                            • C
                              castromann
                              • etc....
                              Ok, I played around with the different tools for some time each. Problem is: There's seems to be no pattern in when or which tool crashes. Sometimes first click into the canvas, sometimes some control points into the operation. It seems that each tool crashes equally probable.
                              Let me know if I can do anything else to find the cause of this?!
                              • fredo6F
                                Apparently the problem occurs on Mac (and possibly on some versions of OSX) and the subsequent problem is that I don't have a Mac to try reproduce it.
                                So, currently I see two ways to progress:
                                1. when you get the bug splat, please send it with comments that this is about BezierSpline. The sketchup team may identify the area or operations which is guilty.
                                2. By chance or by accident, you may find a configuration where the crash is reproducible. If so, let me know, as I can ship a version equipped with traces to find out where it could be.
                                • T
                                  tedvitale
                                  Ive been running into similar issues over the past 3 weeks now. Sketchup has become very unstable using any of the Fredo tools (running SKU Pro 2013), but the root of it seems to stem from a plugin I installed called the Energy Plus Legacy Open Studio (its utter crap ans also breaks V-Ray and a bunch of other plugins). Immediately after installing it I've had nothing but headaches. Ive since uninstalled that plugin, uninstalled and reinstaled a fresh version of Sketchup, and reinstalled everything else (fredo and other plugins), so I thought the problems would stop, but It still persists. I get the most issues when running round corners, Joint Push Pull, and Curvizard, as well as the boolean operations native to sketchup.
                                  I used to have a script that I could run that seemed to do the trick, I have no idea what it is or where I got it, but I would run the .bat operation, and it would re-organize the plugins menu and I would get more reliability out of the plugins. However that was in SU 8, I don't know if it would work in 13.
                                  Anyway, all that said, I can reproduce the bug-splat issue consistently by running the round corner operation. Operations to reproduce go like this:
                                  1. open new sketchup scene
                                  2. create geometry
                                  3. run round corners (any of the 3 will do)
                                  4. operation will finish.
                                  5. once the tool is finished; clicking, closing or any next operation will result in a sketchup bug-splat.
                                  Ill check tomorrow when I get to work, see if its pulling too much memory and thats crashing SU or maybe theres a background operation that keeps running causing the crash? Im not really sure. But things are not going well at the moment. I'm pretty sure its a plugin conflict, I'm just not sure where because everything was running great 3 weeks ago and thats the setup Ive reverted too.
                                  Ted Vitale
                                  3D Artist and designer
                                  Sketchup 2013 Pro
                                    Vray has been known to cause conflicts with other plugins too. Did you try disabling it as well?
                                    • TedVitale_CGT
                                      TedVitale_CG
                                      I'm working on a recent build of V-Ray now, it doesn't seem to make a difference if it's installed or not. But I'll remove it and see if the issue persists. It hasn't been causing problems, however somthing in the most recent nightly may be doing it. We shal see.
                                      Ted Vitale
                                      Owner | Creative Director
                                      http://www.voxl.vision
                                        I've not had any issues with any of Fredo's tools causing SU to crash but then I don't have any of those plugins that are known to cause problems. Maybe the latest build of the Vray plugin is better but it has been known to cause problems for a lot of users. This has been widely reported here on SCF.
                                        Another thing to look at is the permissions for the Plugins folder. Make sure all users have full permissions established.
                                        • 2 / 2
