    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      10Q
        OK, LibTraductor disabled. The rescue statement revised.
        Upon opening SketchUp I still get the error:
        %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
        uninitialized constant Bezierspline::BezierContext::Traductor
        Error Loading File bezierspline.rb
        Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
        no such file to load -- libtraductor.rb
        Error Loading File jointpushpull.rb
        no such file to load -- libtraductor.rb]
        Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
        • F
          fatboycakeshop
          Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
          • nigel_edwardN
            nigel_edward
            Bloody well brilliant tool! Thank you so much! 👍 😍
            • U
              ukchoiceshops
              I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated 😄
              • mitcorbM
                mitcorb
                Hi, Ross:
                Did you read the advice for Mac users on the first page of this topic?
                Alternatively, have you considered using the Sketchucation Plugin Store tool?
                http://sketchucation.com/resources/plugin-store-download
                At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
                There may be some other issue, so post back for someone to assist.
                  aydee
                  Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
                  • O
                    oli_sketch
                    Dear Fredo,
                    I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
                    My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
                    Can you help me.
                    Thank you and kind regards.
                    • B
                      BillyRX
                      @oli_sketch said:
                      Dear Fredo,
                      Can you help me.
                      What he said. Please. This used to be my most commonly used extension. 😞
                      • BoxB
                        There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
                        • B
                          Beejeez
                          I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
                          I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
                          Thanks in advance
                          • fredo6F
                            NEW RELEASE 1.6a - 11 Nov 2013
                            This release is for future Sketchup compatibility
                            Download new release at main post
                            • fredo6F
                              NEW RELEASE 1.6b - 12 Nov 2013
                              It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.
                                Makolee
                                THX FOR THIS PLUGIN
                                • gonashviliG
                                  gonashvili
                                  Hi there
                                  So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
                                  Cheers
                                  • mitcorbM
                                    mitcorb
                                    Hi.
                                    After reading gonashvili's post above, I opened Sketchup8 to test the spline. I placed an initial spline in an empty scene with 0 default setting. Then began to place another, but changed the parameter to 10 and OK. I got a bugsplat window. I captured the window and the response. Interestingly, I immediately repeated the process and got no error.
                                    Sorry, if the two images appear out of order. The splat window is first and the response window is supposed to be second.
                                    Also, apology to gonashvili for jumping in here. I was simply investigating.
                                      suHappyPills
                                      cool tools,Thx a lot.
                                      • robertWanR
                                        robertWan
                                        I type radius 10 mm, but have 14,1. (sqrt200 😒 )
                                        Robert
                                        • fredo6F
                                          NEW RELEASE 1.6c - 03 Mar 14
                                          This release is fixes a bug in the TBone curves, found by Robert Wan.
                                          Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13.
                                          Download latest release if BezierSpline at main post
                                          • robertWanR
                                            robertWan
                                            Thank you for the correction.
                                            If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
                                            Robert
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
