    SketchUp 2013 Gripes & Bitchin' ONLY ;)
    306 Posts 54 Posters 84.4k Views 54 Watching
      @mike amos said:
      I still find that changing tools is a pita, I have to select the new tool multiple times and am forever getting caught out when the tool STILL does not change over, then another crash because the program cannot deal with multiple tool requests.
      Never experienced that. Does it also occur when plugins are disabled?
      • jeff hammondJ
        on the rhino or sketchup thing..
        i'm in the middle of a concrete project right now.. i like to use software to get cutlists to the crew.
        super offtopic but..
        here's some time lapse footage of the stuff i posted on page9 being built..
          Yes, it does at that. Corrupt install or just plain ol' pita from the random world that is sketchup (OR ANY OTHER SOFTWARE BEFORE SOMEONE MENTIONS IT).
            You experience this in other applications as well?
            Any chance you use a wireless mouse? Checked if it needs new batteries?
              No problem with other programs, no wireless mouse, no difference with fresh installs either.
              • C
                congellous
                I was ecstatic with the ease of installing plug ins, new computer, new sketchup pro 2013 and then I tried to use it - Bezier tools Fredo = bug splat over and over, Extrusion tools bug splat, I haven't been able to do a serious project on it. Any advice ?
                I'm on OSX 10.8.4, Sk2013
                  Have you reinstalled fresh versions of the tools ?
                  Some were specifically reworked to be compatible with v2013. Also ensure you have the latest Libs for both Fredo and Thomthom's tools.
                  What is your plugins folder path ?
                  Do you also have Vray beta installed - this tool is known to cause splats when other legit tools do something that its flaky observers take exception to... They are working on a fix... meanwhile you don't need a renderer while you are modeling, so disable it until you need it...
                  • sketch3d.deS
                    sketch3d.de
                    Any advice ?
                    yes, don't copy the ol' stuff from your SU8 plugin folder to SU13 but install the recent versions of the plugins either from inside SU ("Window > Extension Warehouse") resp. download the RBZ/ZIPs from here maybe by using the SketchUCation Plugin Store.
                    SU13 Plugin Folder OSX:
                    Mac HD > Users > [Username] > Library > Application Support > SketchUp 2013 > SketchUp > Plugins
                    hth,
                    Norbert
                    • C
                      congellous
                      Thanks for your comments - I have only installed through the inbuilt plug in whorehouse or the new sketchucation thingy which is very impressive. No old plug ins, no Vray, I've got podium and artisan and I've only downloaded the latest through these channels.
                      • arail1A
                        arail1
                        [quote="Jeff Hammond"][offtopic]
                        Completely off off off topic (the phrase suggests an off Broadway play with a lot of nudity) - do you just build the skateboard parks or do you skate also?
                        • BoxB
                          @congellous said:
                          installed through the inbuilt plug in whorehouse .
                          There is an awful lot of money to be made if you can developed that plugin.
                          • sketch3d.deS
                            sketch3d.de
                            like πŸ˜„
                            • C
                              congellous
                              It's the Bezier, I have downloaded the latest 2013 Fredo lib, however, is there a way to deinstall just to check
                              • jeff hammondJ
                                both.. but i was never good enough to turn pro so i've found other ways to work in the industry πŸ˜‰
                                • C
                                  craigcampbell66
                                  [quote="jason_maranto"]Alright, so hopefully I clearly established why I think this β€œupgrade” fails... Lets look at what you can do about it.
                                  First off, don't β€œupgrade” – if you are free version user don't pay the $590... and if you are an existing Pro user don't pay the $95.
                                  Jason, well thought out and said. I have been an avid user and proponent of sketchup for some time now and was also dismayed at the immediacy of their annual subscription policy. Agree also that the changes/improvements over the past several years (I have used it since SU6) would not have amounted to much without the efforts and skills of the user community in producing plugins to 'get the job done'. What's more, the 3D warehouse is what it is because of the efforts and generosity of this same community.
                                  Should this be their intent for what is generally a loyal customer base then I would urge one and all to lobby Autodessys to get busy with a 'layout' equivalent for Bonzai 3D, which out of the box is similar in price and like Sketchup on steroids. If they were to achieve this, it would result in an enormous migration of 3d modellers to their platform. At the least it would put the pressure back on Trimble to lift their game re their customers.
                                  • L
                                    LooksSketchy2MeXD
                                    Oh FFS... Thank god I've kept that older installer of SketchUp8 around... Wanting to keep everything I have on hand up-to-date, I've just recently tried to update my freeware sketchup to this new sketchup2013.. and to my surprise..
                                    The bloody thing is now a Trial-Ware? 😠 Seriously?! A trial-ware.. I thought I followed the link to the freeware version, same as I've always done since SketchUp 6 and 7... but to my surprise, no matter how hard I've skimmed over Trimble's site looking for the freeware SU.. I dunt find any!! ❓
                                    Needless to say I've un-installed SU2013 and I'm reinstalling SU8, compatible with all of my older plug-ins like Fredo, and others..
                                    I thought SketchUp was supposed to be 3D for everyone.. for the masses? How is it for the masses when it's a trial-ware that last only a week.. or I don't know... as soon as I saw SU2013 was trial-ware I uninstalled it no sooner had I launched it to see what all the fuss was about.
                                    Correct me if I'm wrong about this, everyone, please? But I thought there ALWAYS was a freeware version of SketchUp to go hand in hand with the Pro version since the freeware was thought to be more suitable for the hobbyist and students alike, such as myself, a hobbyist..
                                    Seriously, I think someone has made a dreadful error here removing the freeware version.
                                    Pardon me gents, but I'm back to reinstalling SU8 and all of my plug-ins. XD
                                    End rant.. LooksSketchy2Me
                                      The v2013 'pro-trial' expires and becomes the free version [aka 'make'], it's little different from the v8 but now you don't need to uninstall the expired pro and install free the reversion i automatic... [but there ARE some notable licensing differences...]
                                      Many v8 plugins will continue to work OK in v2012.
                                      Those that were found to need some tweaking have been upgraded.
                                      Suitable versions of most available plugins are available from the SCF PluginStore for download and installation into v2013 [or v8!]
                                      It's recommended that you install the latest versions of all plugins, especially when changing to a new version of any app...
                                      • L
                                        LooksSketchy2MeXD
                                        Oh I see now. ^ ^ Perhaps I've spoken a bit too soon then. Very well I shall reinstall the newer SU2013 and give it a go, but for sanity sake and the sake of keeping an option open, I shall keep the older SU8 in a different directory for easy access and use. =D
                                        • cheddaC
                                          chedda
                                          I cannot seem to change the FOV from deg to mm in the osx 2013 version. Is anyone else having this problem ? I prefer working in mm rather than degrees. I can write mm in the window but after hitting return it defaults to degrees. Is there a workaround for this ? Many thanks in advance.
                                          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                            That's the default anyway. New major SketchUp version always install independently from previous versions and run side by side.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
