    SketchUp 2013 Gripes & Bitchin' ONLY ;)
    306 Posts 54 Posters 84.4k Views 54 Watching
      Don't think that refer to 64bit being speedier. From that one could say 64bit is more modular - which also makes so sense - 64bit is just larger data structures. Nothing related to speed or modularity in any way. I think one should read that is "Flash Professional CC is more modular ".
      @pixero said:
      How come other software companies says their new 64bit application is faster
      I'd recommend a read up on "64bit myth" - where you get full technical details and a number of developers.
      Examples:
      http://www.synfire.com/content/myths-and-facts-about-64-bit
      https://www.ableton.com/en/articles/64bit-myths-facts/
      http://jervisdabreo.com/thetechcorner/tech-myth-a-64-bit-operating-system-is-faster/
      • PixeroP
        Pixero
        Yeah, but I read one note in Swedish saying:
        "•Flash Pro CC – helt ombyggd 64-bitarsarkitektur ska göra programmet snabbare och stabilare."
        I just googled to find something in english for the post.
          Again - that's referring to "Flash Pro CC", not 64bit. Though it can appear misleading the way they present it there.
          • sketch3d.deS
            sketch3d.de
            will be interesting to see all these users demanding a 64bit version bitching here again why there 4gb models are soooooo slow...
            scnr
            Norbert
              x_X
              I'm falling into the same old trap...
              • bmikeB
                bmike
                the icons that follow my cursor around sometimes get sticky.
                orbit seems to do it most often.
                when i spacebar back to select... i'll be stuck with orbit.
                have to manually go up and hit the icon, and then things switch over.
                latest SU pro 2013 update, latest and greatest mac osx.
                  Mra
                  @thomthom said:
                  Anyone else experience crashes with "X-ray mode on" with quadros?
                  I got a Quadro 3800FX - no issues here. Driver version: 311.50.
                  Do you have issues on all models? And it doesn't crash is you disable Hardware Acceleration? What about plugins - does it crash when plugins are disabled?
                  It only happens like 30% of the time on a particularly heavy model, I'm running a Quadro 2000 with 311.50.
                  Thanks though, I think it must be this particular model.
                    I still find that changing tools is a pita, I have to select the new tool multiple times and am forever getting caught out when the tool STILL does not change over, then another crash because the program cannot deal with multiple tool requests.
                      Never experienced that. Does it also occur when plugins are disabled?
                      • jeff hammondJ
                        on the rhino or sketchup thing..
                        i'm in the middle of a concrete project right now.. i like to use software to get cutlists to the crew.
                        super offtopic but..
                        here's some time lapse footage of the stuff i posted on page9 being built..
                          Yes, it does at that. Corrupt install or just plain ol' pita from the random world that is sketchup (OR ANY OTHER SOFTWARE BEFORE SOMEONE MENTIONS IT).
                            You experience this in other applications as well?
                            Any chance you use a wireless mouse? Checked if it needs new batteries?
                              No problem with other programs, no wireless mouse, no difference with fresh installs either.
                              • C
                                congellous
                                I was ecstatic with the ease of installing plug ins, new computer, new sketchup pro 2013 and then I tried to use it - Bezier tools Fredo = bug splat over and over, Extrusion tools bug splat, I haven't been able to do a serious project on it. Any advice ?
                                I'm on OSX 10.8.4, Sk2013
                                  Have you reinstalled fresh versions of the tools ?
                                  Some were specifically reworked to be compatible with v2013. Also ensure you have the latest Libs for both Fredo and Thomthom's tools.
                                  What is your plugins folder path ?
                                  Do you also have Vray beta installed - this tool is known to cause splats when other legit tools do something that its flaky observers take exception to... They are working on a fix... meanwhile you don't need a renderer while you are modeling, so disable it until you need it...
                                  • sketch3d.deS
                                    sketch3d.de
                                    Any advice ?
                                    yes, don't copy the ol' stuff from your SU8 plugin folder to SU13 but install the recent versions of the plugins either from inside SU ("Window > Extension Warehouse") resp. download the RBZ/ZIPs from here maybe by using the SketchUCation Plugin Store.
                                    SU13 Plugin Folder OSX:
                                    Mac HD > Users > [Username] > Library > Application Support > SketchUp 2013 > SketchUp > Plugins
                                    hth,
                                    Norbert
                                    • C
                                      congellous
                                      Thanks for your comments - I have only installed through the inbuilt plug in whorehouse or the new sketchucation thingy which is very impressive. No old plug ins, no Vray, I've got podium and artisan and I've only downloaded the latest through these channels.
                                      • arail1A
                                        arail1
                                        [quote="Jeff Hammond"][offtopic]
                                        Completely off off off topic (the phrase suggests an off Broadway play with a lot of nudity) - do you just build the skateboard parks or do you skate also?
                                        • BoxB
                                          @congellous said:
                                          installed through the inbuilt plug in whorehouse .
                                          There is an awful lot of money to be made if you can developed that plugin.
                                          • sketch3d.deS
                                            sketch3d.de
                                            like 😄
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
