    SketchUp 2013 Gripes & Bitchin' ONLY ;)
    306 Posts 54 Posters 64.2k Views 54 Watching
      Again - that's referring to "Flash Pro CC", not 64bit. Though it can appear misleading the way they present it there.
      • sketch3d.deS Offline
        sketch3d.de
        @thomthom said:
        Don't think that refer to 64bit being speedier.
        will be interesting to see all these users demanding a 64bit version bitching here again why there 4gb models are soooooo slow...
        scnr
        Norbert
          x_X
          I'm falling into the same old trap...
          • bmikeB Offline
            bmike
            the icons that follow my cursor around sometimes get sticky.
            orbit seems to do it most often.
            when i spacebar back to select... i'll be stuck with orbit.
            have to manually go up and hit the icon, and then things switch over.
            latest SU pro 2013 update, latest and greatest mac osx.
              Mra
              @thomthom said:
              Anyone else experience crashes with "X-ray mode on" with quadros?
              I got a Quadro 3800FX - no issues here. Driver version: 311.50.
              Do you have issues on all models? And it doesn't crash is you disable Hardware Acceleration? What about plugins - does it crash when plugins are disabled?
              It only happens like 30% of the time on a particularly heavy model, I'm running a Quadro 2000 with 311.50.
              Thanks though, I think it must be this particular model.
                I still find that changing tools is a pita, I have to select the new tool multiple times and am forever getting caught out when the tool STILL does not change over, then another crash because the program cannot deal with multiple tool requests.
                  Never experienced that. Does it also occur when plugins are disabled?
                  • jeff hammondJ Offline
                    on the rhino or sketchup thing..
                    i'm in the middle of a concrete project right now.. i like to use software to get cutlists to the crew.
                    super offtopic but..
                    here's some time lapse footage of the stuff i posted on page9 being built..
                      Yes, it does at that. Corrupt install or just plain ol' pita from the random world that is sketchup (OR ANY OTHER SOFTWARE BEFORE SOMEONE MENTIONS IT).
                        You experience this in other applications as well?
                        Any chance you use a wireless mouse? Checked if it needs new batteries?
                          No problem with other programs, no wireless mouse, no difference with fresh installs either.
                            congellous
                            I was ecstatic with the ease of installing plug ins, new computer, new sketchup pro 2013 and then I tried to use it - Bezier tools Fredo = bug splat over and over, Extrusion tools bug splat, I haven't been able to do a serious project on it. Any advice ?
                            I'm on OSX 10.8.4, Sk2013
                              Have you reinstalled fresh versions of the tools ?
                              Some were specifically reworked to be compatible with v2013. Also ensure you have the latest Libs for both Fredo and Thomthom's tools.
                              What is your plugins folder path ?
                              Do you also have Vray beta installed - this tool is known to cause splats when other legit tools do something that its flaky observers take exception to... They are working on a fix... meanwhile you don't need a renderer while you are modeling, so disable it until you need it...
                                sketch3d.de
                                Any advice ?
                                yes, don't copy the ol' stuff from your SU8 plugin folder to SU13 but install the recent versions of the plugins either from inside SU ("Window > Extension Warehouse") resp. download the RBZ/ZIPs from here maybe by using the SketchUCation Plugin Store.
                                SU13 Plugin Folder OSX:
                                Mac HD > Users > [Username] > Library > Application Support > SketchUp 2013 > SketchUp > Plugins
                                hth,
                                Norbert
                                  congellous
                                  Thanks for your comments - I have only installed through the inbuilt plug in whorehouse or the new sketchucation thingy which is very impressive. No old plug ins, no Vray, I've got podium and artisan and I've only downloaded the latest through these channels.
                                  • arail1A Offline
                                    arail1
                                    [quote="Jeff Hammond"][offtopic]
                                    Completely off off off topic (the phrase suggests an off Broadway play with a lot of nudity) - do you just build the skateboard parks or do you skate also?
                                    • BoxB Offline
                                      @congellous said:
                                      installed through the inbuilt plug in whorehouse .
                                      There is an awful lot of money to be made if you can developed that plugin.
                                        sketch3d.de
                                        like πŸ˜„
                                          congellous
                                          It's the Bezier, I have downloaded the latest 2013 Fredo lib, however, is there a way to deinstall just to check
                                            both.. but i was never good enough to turn pro so i've found other ways to work in the industry πŸ˜‰
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
