    Sketchup 2013 issues
    208 Posts 53 Posters 59.1k Views 53 Watching
    • KrisidiousK
      Krisidious
      use that browse feature to find the SU V8 exe and then make sure that "Always use this application is checked" it should then default back to SU8.
      By: Kristoff Rand
        It doesn't remember your setting after you've browsed your way to Sketchup.exe?
        • KrisidiousK
          Krisidious
          You also might try the down arrow just under Chrome, (Other Programs) it may show SketchUp with out browsing to it.
          By: Kristoff Rand
          • david_hD
            david_h
            Tried that several times. . .and it won't let me select Sketchup.exe or remember it. I will give it another go based on your suggestions.
            Thanks guys.
            D
            UPDATE . .when I click the down arrow to show additional programs. . .Sketchup Doesn't show up.
            • KrisidiousK
              Krisidious
              Thanks guys.
              D
              You're right... I just tried it and it won't go back to SU V8. This is not good.
              By: Kristoff Rand
                Google want it back
                • EdsonE
                  Edson
                  @chris fullmer said:
                  Not a bad suggestion. Its too late at this point, but it could be a feature for the future. For now, you can differentiate by the default tool icons, if that helps.
                  in macs, if you have 8 and 2013 side by side on the dock, you can see that the 2013 icon is noticeably smaller thanthe previous one.
                  http://www.mahfuz.arq.br
                  • david_hD
                    david_h
                    @rich o brien said:
                    Google want it back
                    Well that's it. I'm bolting over to Form Z--
                    or at least form Y --it's an earlier version. Probably cheaper. πŸ’š
                    • Dan RathbunD
                      Dan Rathbun
                      What if you run SU 8, then close it.
                      Hoping it will reset the file association. At least it DOES on XP, AFAIK.
                      I'm not here much anymore.
                      • KrisidiousK
                        Krisidious
                        Dan, Yes that did fix it. SU v8 is now the default program to open SU files...
                        By: Kristoff Rand
                          jpalm32
                          I had this happen before '13. Trird everything, after a MS update, reboot, all was fine.
                          It wasn't the update, just the hard re-boot.
                          • david_hD
                            david_h
                            Did the hard re-boot. .. really hard. Steel-toed. . .
                            I opened SU and ran it a bit. Closed. Did the hard re-boot. . .
                            Did I miss a step?
                              jpalm32
                              Didn't work. . .[attachment=0:15q8qcdn]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:15q8qcdn]
                              Did I miss a step?
                              Nope!
                              Sorry that what worked for me.
                              Did open SU8 and load some files saved/closed a few times.
                              • KrisidiousK
                                Krisidious
                                open SU V8
                                close it.
                                find a file of V8 skp and right click on it.
                                open with.
                                navigate to the V8 exe.
                                click ok
                                should open in V8 now.
                                By: Kristoff Rand
                                • P
                                  Penguin2
                                  Toolbars for Plugins missing.
                                  Loaded the following from EW:-
                                  'Selection Toys'
                                  'Edge Tools2'
                                  Tried un-checking then re-checking in Toolbar list. Still not visible.
                                  I am finding this release very frustrating. EW doesn't work for me and the whole presentation is ???
                                  If I could get the installation from EW to work I might be persuaded to continue despite the smaller awful red tool icons (not very professional).
                                  Has anyone else had these problems?
                                  Cheers
                                  Penguin2
                                  • soloS
                                    'Selection Toys'
                                    'Edge Tools2'
                                    Cheers
                                    Penguin2
                                    Try restarting SU.
                                    • K
                                      kaas
                                      'Selection Toys'
                                      'Edge Tools2'
                                      Had the same problem with the selection toys. After downloading the latest version and manually installing the plugin (copy files to plugin directory) it works.
                                      • C
                                        cuttingedge
                                        I had bugsplat after bugsplat after bugsplat just using roundcorners plugin.
                                        Copy- paste from skp 2013 to version 8 is not possible.
                                        I feel that the icons in version 8 looks better than 2013
                                        The right click for turning on and off plugins is really handy but icons don't stay in place after restart.
                                        • plesiosaurP
                                          plesiosaur
                                          I noticed that Fredo6’s plugins do not appear in the EW, does anyone know why?
                                          Also, the Fredo6 plugins that I installed in SU2013 do not work, these are the error messages I’m getting:
                                          "Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
                                          C:/Program Files (x86)/SketchUP/SketchUP 2013/Plugins
                                          Please create it manually, respecting the case"
                                          Also,
                                          "Error Loading File LibFredo6.rb
                                          undefined method 'average_load_time' for
                                          Traductor::Plugin:Class"
                                          Is anyone else experiencing a similar problem? Does anyone have a suggestion, I use the roundcorners.rb and FredoTools.rb a lot.
                                          • plesiosaurP
                                            plesiosaur
                                            FYI for those who use 3Dconnexion products:
                                            I am, or have been, using a 3Dconnecxion SpacePilot Pro with SU8; it appears that 3Dconnexion does not play well with SU2013, at least not for me.
                                            • 11
                                            • 4 / 11
