    Sketchup 2013 issues
    208 Posts 53 Posters 32.5k Views 53 Watching
    • daleD Offline
      dale
      So Tomasz, would it be better to hold off on upgrading until Thea is fully functional on Mac?
      I rely on Thea for work, and deadlines usually mean no time for screw ups.
      Is there a timeframe on the Mac fix?
        tomasz
        I am working on it as we speak. It is a highest priority for me to fix it.
        Please hold off with the full switch to SU2013.
        This shouldn't stop you from testing the new version, but at the moment Thea is not correctly reading materials inside SU2013 for Mac.
        I hope the fix will be ready in few days.
        • daleD Offline
          dale
          Thanks Tomasz, both for your quick reply, and all your hard work.
          Think I'll just hang on.
            ArCAD-UK
            I reinstalled Twilight and it seems to be working as expected. Profile Builder's preview window is broken.
            • KrisidiousK Offline
              Krisidious
              Here's the fix.
              By: Kristoff Rand
              • david_hD Offline
                david_h
                I have a bit of a problem with which I hope you guys can help . .
                I downloaded 2013 for a minute, but changed my mind and off-loaded it immediately. (Nothin' against 13 per se I just didn't have time to play with it and decided to download it later) I did nothing else with my file structure. SU 8 still in tact, etc.
                However . . .now all of my SKP files have been Hi-jacked by Google as the Default program and the "open with" won't let me changeit back to SU for some reason. So I have to open SU first and then hunt for the file thru the "Open" pull down in SU rather than just double-click on the file itself to open it.
                Any ideas on how to fix this?
                Thx in advance.
                David
                  Krisidious
                  use that browse feature to find the SU V8 exe and then make sure that "Always use this application is checked" it should then default back to SU8.
                  By: Kristoff Rand
                    It doesn't remember your setting after you've browsed your way to Sketchup.exe?
                      Krisidious
                      You also might try the down arrow just under Chrome, (Other Programs) it may show SketchUp with out browsing to it.
                      By: Kristoff Rand
                      • david_hD Offline
                        david_h
                        Tried that several times. . .and it won't let me select Sketchup.exe or remember it. I will give it another go based on your suggestions.
                        Thanks guys.
                        D
                        UPDATE . .when I click the down arrow to show additional programs. . .Sketchup Doesn't show up.
                          Krisidious
                          Thanks guys.
                          D
                          You're right... I just tried it and it won't go back to SU V8. This is not good.
                          By: Kristoff Rand
                            Google want it back
                            • EdsonE Offline
                              Edson
                              @chris fullmer said:
                              Not a bad suggestion. Its too late at this point, but it could be a feature for the future. For now, you can differentiate by the default tool icons, if that helps.
                              in macs, if you have 8 and 2013 side by side on the dock, you can see that the 2013 icon is noticeably smaller thanthe previous one.
                              http://www.mahfuz.arq.br
                              • david_hD Offline
                                david_h
                                @rich o brien said:
                                Google want it back
                                Well that's it. I'm bolting over to Form Z--
                                or at least form Y --it's an earlier version. Probably cheaper. πŸ’š
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  What if you run SU 8, then close it.
                                  Hoping it will reset the file association. At least it DOES on XP, AFAIK.
                                  I'm not here much anymore.
                                    Krisidious
                                    Dan, Yes that did fix it. SU v8 is now the default program to open SU files...
                                    By: Kristoff Rand
                                      jpalm32
                                      I had this happen before '13. Trird everything, after a MS update, reboot, all was fine.
                                      It wasn't the update, just the hard re-boot.
                                      • david_hD Offline
                                        david_h
                                        Did the hard re-boot. .. really hard. Steel-toed. . .
                                        I opened SU and ran it a bit. Closed. Did the hard re-boot. . .
                                        Did I miss a step?
                                          jpalm32
                                          Didn't work. . .[attachment=0:15q8qcdn]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:15q8qcdn]
                                          Did I miss a step?
                                          Nope!
                                          Sorry that what worked for me.
                                          Did open SU8 and load some files saved/closed a few times.
                                            Krisidious
                                            open SU V8
                                            close it.
                                            find a file of V8 skp and right click on it.
                                            open with.
                                            navigate to the V8 exe.
                                            click ok
                                            should open in V8 now.
                                            By: Kristoff Rand
                                            • 11
                                            • 3 / 11
