    Sketchup 2013 issues
    208 Posts 53 Posters 59.1k Views 53 Watching
    • KrisidiousK
      Krisidious
      Dan, Yes that did fix it. SU v8 is now the default program to open SU files...
      By: Kristoff Rand
        jpalm32
        I had this happen before '13. Trird everything, after a MS update, reboot, all was fine.
        It wasn't the update, just the hard re-boot.
        • david_hD
          david_h
          Did the hard re-boot. .. really hard. Steel-toed. . .
          I opened SU and ran it a bit. Closed. Did the hard re-boot. . .
          Did I miss a step?
            jpalm32
            Didn't work. . .[attachment=0:15q8qcdn]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:15q8qcdn]
            Did I miss a step?
            Nope!
            Sorry that what worked for me.
            Did open SU8 and load some files saved/closed a few times.
            • KrisidiousK
              Krisidious
              open SU V8
              close it.
              find a file of V8 skp and right click on it.
              open with.
              navigate to the V8 exe.
              click ok
              should open in V8 now.
              By: Kristoff Rand
              • P
                Penguin2
                Toolbars for Plugins missing.
                Loaded the following from EW:-
                'Selection Toys'
                'Edge Tools2'
                Tried un-checking then re-checking in Toolbar list. Still not visible.
                I am finding this release very frustrating. EW doesn't work for me and the whole presentation is ???
                If I could get the installation from EW to work I might be persuaded to continue despite the smaller awful red tool icons (not very professional).
                Has anyone else had these problems?
                Cheers
                Penguin2
                • soloS
                  'Selection Toys'
                  'Edge Tools2'
                  Cheers
                  Penguin2
                  Try restarting SU.
                  • K
                    kaas
                    'Selection Toys'
                    'Edge Tools2'
                    Had the same problem with the selection toys. After downloading the latest version and manually installing the plugin (copy files to plugin directory) it works.
                    • C
                      cuttingedge
                      I had bugsplat after bugsplat after bugsplat just using roundcorners plugin.
                      Copy- paste from skp 2013 to version 8 is not possible.
                      I feel that the icons in version 8 looks better than 2013
                      The right click for turning on and off plugins is really handy but icons don't stay in place after restart.
                      • plesiosaurP
                        plesiosaur
                        I noticed that Fredo6โ€™s plugins do not appear in the EW, does anyone know why?
                        Also, the Fredo6 plugins that I installed in SU2013 do not work, these are the error messages Iโ€™m getting:
                        "Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
                        C:/Program Files (x86)/SketchUP/SketchUP 2013/Plugins
                        Please create it manually, respecting the case"
                        Also,
                        "Error Loading File LibFredo6.rb
                        undefined method 'average_load_time' for
                        Traductor::Plugin:Class"
                        Is anyone else experiencing a similar problem? Does anyone have a suggestion, I use the roundcorners.rb and FredoTools.rb a lot.
                        • plesiosaurP
                          plesiosaur
                          FYI for those who use 3Dconnexion products:
                          I am, or have been, using a 3Dconnecxion SpacePilot Pro with SU8; it appears that 3Dconnexion does not play well with SU2013, at least not for me.
                          • Alan FraserA
                            Alan Fraser
                            Unless that's a typo on your part, the fault may lie in the syntax. SketchUp shouldn't have a capital P.
                            I can't say I've had any problem with any of Fredo's plugins...Round Corners included, after I upgraded the LibFredo6 Library files.
                            3D Figures
                            • BoxB
                              For those with missing toolbars, check that they aren't hiding under the others.
                              There are a few that get stuck at the top left.
                              Close all the others or drag them off the top. If there is one stuck there under "File" you can usually release it by double clicking on it.
                              • plesiosaurP
                                plesiosaur
                                Alan, the syntax is per the SU2013 installation, just for kicks I renamed the folder with a lower case "p" - same error messages; I deleted all of the Fredo6 plugins and folders from my SU2013 plugins folder then re-re-installed all of them; again, same error messages. I may have to re-install SU2013 to see if that fixes it.
                                  Did you try right clicking the SU2013 icon and choosing Run as Admin?
                                  • plesiosaurP
                                    plesiosaur
                                    Rich, you're the man! Thanks!
                                    • KrisidiousK
                                      Krisidious
                                      I also have to re-select toolbars after restarting the system.
                                      By: Kristoff Rand
                                      • BoxB
                                        I can't for the life of me find how to turn off the "Welcome to sketchup" screen. It opens every time even if I already have SU open and will only go away by clicking, Start using.....
                                        Is this nagware that only goes away with Pro, or am I even more stupid than usual?
                                        • KrisidiousK
                                          Krisidious
                                          should be a check box to turn it off right in the window itself... at the bottom.
                                          By: Kristoff Rand
                                          • BoxB
                                            That was the first place I looked, but no.
                                            If you are telling me it does exist then I need to adjust my resolution again to find it.
                                            • 11
                                            • 4 / 11
