    Sketchup 2013 issues
    208 Posts 53 Posters 54.8k Views 53 Watching
    • KrisidiousK
      Krisidious
      @krisidious said:
      use that browse feature to find the SU V8 exe and then make sure that "Always use this application is checked" it should then default back to SU8.
      It doesn't remember your setting after you've browsed your way to Sketchup.exe?
      @krisidious said:
      You also might try the down arrow just under Chrome, (Other Programs) it may show SketchUp with out browsing to it.
      Tried that several times. . .and it won't let me select Sketchup.exe or remember it. I will give it another go based on your suggestions.
      Thanks guys.
      D
      UPDATE . .when I click the down arrow to show additional programs. . .Sketchup Doesn't show up.
      You're right... I just tried it and it won't go back to SU V8. This is not good.
      By: Kristoff Rand
        Google want it back
        • EdsonE
          Edson
          @chris fullmer said:
          Not a bad suggestion. Its too late at this point, but it could be a feature for the future. For now, you can differentiate by the default tool icons, if that helps.
          in macs, if you have 8 and 2013 side by side on the dock, you can see that the 2013 icon is noticeably smaller thanthe previous one.
          http://www.mahfuz.arq.br
          • david_hD
            david_h
            @rich o brien said:
            Google want it back
            Well that's it. I'm bolting over to Form Z--
            or at least form Y --it's an earlier version. Probably cheaper. πŸ’š
            • Dan RathbunD
              Dan Rathbun
              What if you run SU 8, then close it.
              Hoping it will reset the file association. At least it DOES on XP, AFAIK.
              I'm not here much anymore.
              • KrisidiousK
                Krisidious
                Dan, Yes that did fix it. SU v8 is now the default program to open SU files...
                By: Kristoff Rand
                  jpalm32
                  I had this happen before '13. Trird everything, after a MS update, reboot, all was fine.
                  It wasn't the update, just the hard re-boot.
                  • david_hD
                    david_h
                    Did the hard re-boot. .. really hard. Steel-toed. . .
                    I opened SU and ran it a bit. Closed. Did the hard re-boot. . .
                    Did I miss a step?
                      jpalm32
                      Didn't work. . .[attachment=0:15q8qcdn]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:15q8qcdn]
                      Did I miss a step?
                      Nope!
                      Sorry that what worked for me.
                      Did open SU8 and load some files saved/closed a few times.
                      • KrisidiousK
                        Krisidious
                        open SU V8
                        close it.
                        find a file of V8 skp and right click on it.
                        open with.
                        navigate to the V8 exe.
                        click ok
                        should open in V8 now.
                        By: Kristoff Rand
                        • P
                          Penguin2
                          Toolbars for Plugins missing.
                          Loaded the following from EW:-
                          'Selection Toys'
                          'Edge Tools2'
                          Tried un-checking then re-checking in Toolbar list. Still not visible.
                          I am finding this release very frustrating. EW doesn't work for me and the whole presentation is ???
                          If I could get the installation from EW to work I might be persuaded to continue despite the smaller awful red tool icons (not very professional).
                          Has anyone else had these problems?
                          Cheers
                          Penguin2
                          • soloS
                            'Selection Toys'
                            'Edge Tools2'
                            Cheers
                            Penguin2
                            Try restarting SU.
                            • K
                              kaas
                              'Selection Toys'
                              'Edge Tools2'
                              Had the same problem with the selection toys. After downloading the latest version and manually installing the plugin (copy files to plugin directory) it works.
                              • C
                                cuttingedge
                                I had bugsplat after bugsplat after bugsplat just using roundcorners plugin.
                                Copy- paste from skp 2013 to version 8 is not possible.
                                I feel that the icons in version 8 looks better than 2013
                                The right click for turning on and off plugins is really handy but icons don't stay in place after restart.
                                • plesiosaurP
                                  plesiosaur
                                  I noticed that Fredo6’s plugins do not appear in the EW, does anyone know why?
                                  Also, the Fredo6 plugins that I installed in SU2013 do not work, these are the error messages I’m getting:
                                  "Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
                                  C:/Program Files (x86)/SketchUP/SketchUP 2013/Plugins
                                  Please create it manually, respecting the case"
                                  Also,
                                  "Error Loading File LibFredo6.rb
                                  undefined method 'average_load_time' for
                                  Traductor::Plugin:Class"
                                  Is anyone else experiencing a similar problem? Does anyone have a suggestion, I use the roundcorners.rb and FredoTools.rb a lot.
                                  • plesiosaurP
                                    plesiosaur
                                    FYI for those who use 3Dconnexion products:
                                    I am, or have been, using a 3Dconnecxion SpacePilot Pro with SU8; it appears that 3Dconnexion does not play well with SU2013, at least not for me.
                                    • Alan FraserA
                                      Alan Fraser
                                      Unless that's a typo on your part, the fault may lie in the syntax. SketchUp shouldn't have a capital P.
                                      I can't say I've had any problem with any of Fredo's plugins...Round Corners included, after I upgraded the LibFredo6 Library files.
                                      3D Figures
                                      • BoxB
                                        For those with missing toolbars, check that they aren't hiding under the others.
                                        There are a few that get stuck at the top left.
                                        Close all the others or drag them off the top. If there is one stuck there under "File" you can usually release it by double clicking on it.
                                        • plesiosaurP
                                          plesiosaur
                                          Alan, the syntax is per the SU2013 installation, just for kicks I renamed the folder with a lower case "p" - same error messages; I deleted all of the Fredo6 plugins and folders from my SU2013 plugins folder then re-re-installed all of them; again, same error messages. I may have to re-install SU2013 to see if that fixes it.
                                            Did you try right clicking the SU2013 icon and choosing Run as Admin?
                                            • 11
                                            • 4 / 11
