    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
    • brodieB
      brodie
      I'm on board with the parallel projection. I find that when you initially change to PP you'll get some bad clipping, but if you select your geometry and then zoom extents the clipping goes away and you can zoom in as much as you want.
      -Brodie
      • V
        valerostudio
        Left, Right, Up arrows lock the Red Green Blue Axis when using move! How did it take me 7 years to figure this one out!
        • gillesG
          gilles
          Seven years!
          You should read the manual, just in case. 😄
          Error 404 (Not Found)!!1
          (support.google.com)
          • V
            valerostudio
            There's a manual? 😉
            • Wo3DanW
              Wo3Dan
              @gilles said:
              Seven years!
              Useful reading but here it lacks the information about how to use to rotate a group or component accurately according to the current drawing axes system with angle input.
              Also I couldn't find anything about moving vertices. And even more, while doing so, how to lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
              • cottyC
                cotty
                @wo3dan said:
                ...lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                New one for me, thank you!
                my SketchUp gallery
                • gillesG
                  gilles
                  Yes nobody is perfect.
                  • gillesG
                    gilles
                    This one is new for me!
                    Well seven years to learn this too. 😳
                    • Wo3DanW
                      Wo3Dan
                      How true.
                      Fact is, I learned it (lock vertex to edge) from someone else, .....from Anssi.
                      And this was also after having used SU for several years. (Doh for me at that time)
                      • GaieusG
                        And not only the Move tool but the line tool, too (just in case you needed it) 😉
                        And yes, I only discovered it about a year ago or so? 😆
                        • broomstickB
                          broomstick
                          There's always something new to learn..
                            A funny thing with soap skin Bubble! 💚
                            you can copy / move, rotate even resize the result "C" before call the button Generate SoapBubble!! 😲
                            for a collective Pressure on some objects from copy moved rotated even resized!
                            But not from different objects Soap Skinned!
                            It's not so bad! ☀
                            Ps And you can of course stop the process make other things then retake them at any moments!
                            Pressure is not additive just absolute! (can be negative or positive)
                              rv1974
                              It's more effective to import DXF file generated from PLT (via Viewcompanion Premium)
                              than original DWG one. No need to mess with Xref binding and parsecs from 0,0,0 👊 .
                                Another in the line of D'oh moments, I am trying to increase the accuracy that sketchup uses to place a point. I have scaled a group by x10 to see what I want to do but even now I find that trying to place a new line results in the start point NOT going where I want it to, rather the point goes only aproximately the same country as the location I want to start from. The start point WILL be another end point OR an intersection. Lovely this memory trick, learn something, leave it unused, forget it.........
                                • DanielD
                                  Daniel
                                  I had an embarrassing DOH! moment the other day...I just discovered the "make component" icon on the toolbar! When was that added? All those years going through the pull-down edit menu.
                                  My avatar is an anachronism.
                                    In what number of version ?
                                    And what is the image of this icon ?
                                    Seems you have also the Shortcut G on a selection ! 💚
                                    • DanielD
                                      Daniel
                                      I've checked and the icon is on 2013, 8, 7, and 6. It might have been on earlier version, but can't confirm.
                                        • F
                                          flyashy
                                          Everyone knows that we can enter value in both Metric and British units regardless of the model units right.
                                          But I recently discovered that we can also combine the two unit systems !!!
                                          That means to move an object I can enter 6'3.5mm in the vcb and sketchup accurately places the object!!!
                                          How cool is that!! 😮
                                          P.S. Doesn't seem to work the other way around tho.. 6M3" seems to give an error of invalid length entered. go figure 😄
                                          • Wo3DanW
                                            Wo3Dan
                                            @flyashy said:
                                            ...That means to move an object I can enter 6'3.5mm in the vcb and sketchup accurately places the object!!!.....
                                            This seems to be an (one of the) exception(s). To move 6"3.5mm does not work. I can't figure out why one dimension would be in two different units anyway. More that X is in one unit, Y in another (and Z in yet another). And you are right, this is also possible in SketchUp.
                                            Example: you can scale a cube in 3 directions to accurate dimensions by applying 1m,10',12" [Enter]
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
