    Sketchup 64 bit?
    170 Posts 35 Posters 54.4k Views 35 Watching
      Khai
      @thomthom said:
      @khai said:
      to give us back the Skp previews....
      SketchUp don't need to go 64bit for that - they only have to update the thumbnailer. (Which I really hope they do.)
      SHHHHHHH it's actually a valid reason! 😉
        dacad
        hahaha great post khai
        But when we stop to think about it, a question pops "why would I need sk 64 bits?" Really why? it's not like SK has the tools to push it much further without help from others, and if it works with others it's because the OTHERS try to work with it, not the other way. And it's not flawless (vrayfur on a imported skp file anyone?)
        If you ask me 6-7 years ago what I though sk would be capable of doing I would have answer something like Lumion does now (it's the perfect philosophy of WYSIWYG that sk had), and more clever and unique modelling/texturing/animation tools (64 bits and multicore wouldn't cross my mind back then). And now remind me what's the big differences in this departments with sk without 3rd party stuff, in 6 years? A little shocking when you think about it, isn't it...
        So be it 32 or 64, I think sk has reach the "mature" point (unfortunately), it's has good as it ever is going to be (just some "optimizations" here and there with newer versions). Just accept it and use it as long as it works for you (it will give us all much less headaches and "beating-dead-horses"-debates).I have.
        So, honestly I think the questions in sk development goes much deeper than plain and simple 64 bits...
        • jason_marantoJ Offline
          jason_maranto
          As long as there are Sketchup Ruby Plugin developers Sketchup will be fine as a modelling tool... The top priority as I see it is for the Sketchup dev team to really take the time to polish up the functionality and documentation of the APIs (Ruby & C++) and add an API for Layout, then some sort of high quality plugin management scheme will probably make most users very happy.
          I do wonder if some very real performance gains could be made by overhauling the internal render engine, because that seems to be the thing that slows down performance the most.
          Best,
          Jason.
          • jbacusJ Offline
            jbacus
            We implemented an entirely new rendering engine in SU7.1, which did increase performance significantly. Historically, every new SketchUp release is faster than its predecessor.
            "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
            John Bacus
            jbacus@sketchup.com
              To be honest I've found SU8 alot more responsive than 7.1 was on my ATI card. And i've also noticed that SU8 is alot quicker when selecting hi-poly(sub-divided) meshes.
              So for me 64bit isn't something I crave, as out of the box SU is still my weapon of choice 👍
              • brodieB Offline
                brodie
                @khai said:
                look at this way.
                Sketchup eventually will go 64bit. it has to. try running an 8bit or 16bit app in windows and you'll see what I mean... so Patience.... it'll get there in the end. 😆
                I think that's actually a pretty interesting point. Looking at it another way, why NOT start pushing for an 16-bit or even 8-bit version of SU? If 64-bit is slower, because of the extra info being pushed through, then it stands to reason that an 8-bit SU would be faster, would it not?
                -Brodie
                • PixeroP Offline
                  Pixero
                  But is it more stable for "polygon heavy" models?
                  I'd rather have a slow but stable SU than a fast and unstable.
                  Do you mean that a 64bit SU wouldn't be more stable for heavy models?
                    The only way it'd be more stable would be if SU ran out of memory while such a model where loaded. Personally I have not seen that, even with 1-2 million faces models. (Faces, not triangles, so the triangle count ( which most apps report in ) will be much higher.)
                    The only times I's crashed SU due to running out of memory has been when I rendered with a render-engine.
                    • jbacusJ Offline
                      jbacus
                      New releases of SketchUp tend towards increased stability. I say that they "tend towards" increased stability because new major versions may be less stable than the preceding maintenance release for the last major version– actually, that's the whole reason for doing maintenance releases. We track "stability" metrics by watching submitted crash reports– so be sure that you're sending those reports in if you're having problems.
                      Unfortunately, as SketchUp's performance and stability increase you are at liberty to make larger and more complex models. Which put new and more taxing requirements on the system as a whole.
                      But, no– 64bit computing won't inherently improve the stability of SketchUp for large models.
                      John Bacus
                      jbacus@sketchup.com
                      • anteolicA Offline
                        anteolic
                        Evrybody says that new sketchup not be 64bit but i got this answer from Trimble
                        Thanks for the note. We don't have an exact date we can share with you to when the next version of SketchUp Pro will be released. We are working on the next version and plan to have it out sometime this year. The plan is to include 64bit functionality.
                        If you need anything else, please let me know.
                          WWWWWWWWWWWOOOOOOOOOOOWWWWWWWWWW!
                          Did you reply? What did you say? 🎉
                          • anteolicA Offline
                            anteolic
                            i dont reply anything, for now thisi is enough information for me. I am very big fun of sketchup i now im very hame to hear that new sketchup will be 64bit.
                            • PixeroP Offline
                              Pixero
                              • pbacotP Offline
                                  64bit functionality not sure if that means SketchUp will be 64bit. Considering John Bacus's replies earlier it appeared that 64bit SketchUp wasn't high up there on the list. So I am surprised if the next release will be so. And more surprised they would mention this to anyone. They never reveal information prior to releases.
                                  Until this is verified I hold back my "wow!".
                                    Party pooper
                                    • anteolicA Offline
                                      anteolic
                                      this was my question to Trimble maybe it will help you
                                      When is comming new sketchup and will it be 64bit. Cause program is perfect but i can work with large scenes
                                      and they answer me:
                                      Kind Regards,
                                      NAME SURNAME-i dont wont write name of agent cause i dont know it is good.
                                      Inside Sales & Support | SketchUp Pro
                                      Trimble Navigation Limited
                                        jason_maranto
                                        If this is correct (and you would hope sales dept. would know the facts) then I will definitely be upgrading to 2013.
                                        Best,
                                        Jason.
                                        • soloS Offline
                                          Could this be true?
                                          http://24.media.tumblr.com/tumblr_m2y59yTtXJ1rrv1jeo1_500.jpg
                                          My skeptical look.
                                            sonder
                                            I'm hopeful! I need to start using all 64Gb of memory in my new machine!
                                            • 2 / 9
