    Sketchup 64 bit?
    170 Posts 35 Posters 54.4k Views 35 Watching
      To be honest I've found SU8 alot more responsive than 7.1 was on my ATI card. And i've also noticed that SU8 is alot quicker when selecting hi-poly(sub-divided) meshes.
      So for me 64bit isn't something I crave, as out of the box SU is still my weapon of choice 👍
      • brodieB Offline
        brodie
        @khai said:
        look at this way.
        Sketchup eventually will go 64bit. it has to. try running an 8bit or 16bit app in windows and you'll see what I mean... so Patience.... it'll get there in the end. 😆
        I think that's actually a pretty interesting point. Looking at it another way, why NOT start pushing for an 16-bit or even 8-bit version of SU? If 64-bit is slower, because of the extra info being pushed through, then it stands to reason that an 8-bit SU would be faster, would it not?
        -Brodie
        • PixeroP Offline
          Pixero
          @jbacus said:
          Historically, every new SketchUp release is faster than its predecessor.
          But is it more stable for "polygon heavy" models?
          I'd rather have a slow but stable SU than a fast and unstable.
          Do you mean that a 64bit SU wouldn't be more stable for heavy models?
            The only way it'd be more stable would be if SU ran out of memory while such a model where loaded. Personally I have not seen that, even with 1-2 million faces models. (Faces, not triangles, so the triangle count ( which most apps report in ) will be much higher.)
            The only times I's crashed SU due to running out of memory has been when I rendered with a render-engine.
            • jbacusJ Offline
              jbacus
              New releases of SketchUp tend towards increased stability. I say that they "tend towards" increased stability because new major versions may be less stable than the preceding maintenance release for the last major version– actually, that's the whole reason for doing maintenance releases. We track "stability" metrics by watching submitted crash reports– so be sure that you're sending those reports in if you're having problems.
              Unfortunately, as SketchUp's performance and stability increase you are at liberty to make larger and more complex models. Which put new and more taxing requirements on the system as a whole.
              But, no– 64bit computing won't inherently improve the stability of SketchUp for large models.
              "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
              John Bacus
              jbacus@sketchup.com
              • anteolicA Offline
                anteolic
                Evrybody says that new sketchup not be 64bit but i got this answer from Trimble
                Thanks for the note. We don't have an exact date we can share with you to when the next version of SketchUp Pro will be released. We are working on the next version and plan to have it out sometime this year. The plan is to include 64bit functionality.
                If you need anything else, please let me know.
                  WWWWWWWWWWWOOOOOOOOOOOWWWWWWWWWW!
                  Did you reply? What did you say? 🎉
                  • anteolicA Offline
                    anteolic
                    i dont reply anything, for now thisi is enough information for me. I am very big fun of sketchup i now im very hame to hear that new sketchup will be 64bit.
                    • PixeroP Offline
                      Pixero
                      • pbacotP Offline
                          64bit functionality not sure if that means SketchUp will be 64bit. Considering John Bacus's replies earlier it appeared that 64bit SketchUp wasn't high up there on the list. So I am surprised if the next release will be so. And more surprised they would mention this to anyone. They never reveal information prior to releases.
                          Until this is verified I hold back my "wow!".
                            Party pooper
                            • anteolicA Offline
                              anteolic
                              this was my question to Trimble maybe it will help you
                              When is comming new sketchup and will it be 64bit. Cause program is perfect but i can work with large scenes
                              and they answer me:
                              Kind Regards,
                              NAME SURNAME-i dont wont write name of agent cause i dont know it is good.
                              Inside Sales & Support | SketchUp Pro
                              Trimble Navigation Limited
                              • jason_marantoJ Offline
                                jason_maranto
                                If this is correct (and you would hope sales dept. would know the facts) then I will definitely be upgrading to 2013.
                                Best,
                                Jason.
                                • soloS Offline
                                  Could this be true?
                                  http://24.media.tumblr.com/tumblr_m2y59yTtXJ1rrv1jeo1_500.jpg
                                  My skeptical look.
                                    sonder
                                    I'm hopeful! I need to start using all 64Gb of memory in my new machine!
                                    • mitcorbM Offline
                                      mitcorb
                                      You might get solicitations from organizations wanting to borrow number crunching time on on your machine, if the 64Gb is any indicator.
                                        Why? When have you run out of memory while using SketchUp?
                                        • soloS Offline
                                          I often forget about which or where plugins are for something I require, so I can say I have a memory issues in SU.
                                            Well played sir, well played!
                                            • 2 / 9
