    Stainless Steel
    renderpluginsextensions
    19 Posts 6 Posters 6.5k Views 6 Watching
    • V Offline
      valerostudio
      I took Vicspa's 02 map and adjusted it to be horizontally tileable and make a reflection map from it. Tweaked a few settings from the suggestions here and I think I got something worthwhile. Add bump for closeups and turn down the subdivs to reduce render times.
      Valero_Stainless.zip
      • V Offline
        Vicspa
        Nice Valero, any issues with tiling?, I know the pattern does not tile, and I've been meaning to make one that does.
        • olisheaO Offline
          olishea
          offset your texture in photoshop down the middle πŸ˜‰ you can see seam in the bump
          oli
          • V Offline
            Vicspa
            The problem with that Olishea is that the linear pattern does not match from one side to the other, it's slightly offset, but it can be done with a little more work in PS.
            • olisheaO Offline
              olishea
              Yes, exactly. You are about to make a horizontally seamless texture. πŸ‘
              oli
              • V Offline
                Vicspa
                Here's one that tiles Ok.
                • massimoM Offline
                  massimo Moderator
                  For this kind of images this little plugin called "tiler" for PS works pretty well (scroll to the bottom of the page). It works also in an image editor like Xnview for example.
                  • V Offline
                    valerostudio
                    I had already fixed the tiling issue with the vismat I attached.
                    • olisheaO Offline
                      olishea
                      Sorry it must have been subdivisions that gave the texture the appearance of being tiled.
                      I was gonna upload my own scratchmap, but nobody would learn anything.
                      Your material is very close, I just believe it needs more reflection to match the photograph you posted. Can you also reduce the blurriness of the reflection in Vray?
                      Basically, the longer you polish stainless steel; the shinier it gets and the bump is reduced.
                      So low polish=high bump low shine. High polish=low bump more shine. πŸ‘
                      It's a very tricky material to achieve....especially as there are so many grades of stainless steel. πŸ˜†
                      oli
                      • V Offline
                        Vicspa
                        Grazie Massimo, I will try it out.
                        Will also try the plugin just below the tiler one called "Ultimate Artist Aggravator"
                        • massimoM Offline
                          massimo Moderator
                          πŸ˜‰
