    Stainless Steel
    renderpluginsextensions
    19 Posts 6 Posters 6.8k Views 6 Watching
    • olisheaO Offline
      olishea
      Tip:
      You can make a stainless steel bumpmap by stretching a noise texture. A scratchmap.
      Go to photoshop. Start with a white canvas and Add Noise. Make sure to check Monochrome.
      Now apply the rain filter which will stretch your Noise Map. Use Free Transform to stretch it even more.
      You can now change the levels/contrast to make the bumps deeper/lighter.
      Stainless Steel gets that sheen on its surface from the manufacturing technique....spinning and polishing. Spun stainless ALWAYS has horizontal polish lines (your new bumpmap/scratchmap).
      See these old threads of mine, it's twilight render but you will see how the bump makes the sheen and will translate into Vray.
      http://i654.photobucket.com/albums/uu269/olishea/orb_high.jpg
      404 Not Found
      (sketchucation.com)
      the material discussion on the twilight render forum:
      http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13968#p13968
      oli
      • soloS Offline
        This is where procedural maps come in handy
        • V Offline
          valerostudio
          I took Vicspa's 02 map and adjusted it to be horizontally tileable and make a reflection map from it. Tweaked a few settings from the suggestions here and I think I got something worthwhile. Add bump for closeups and turn down the subdivs to reduce render times.
          Valero_Stainless.zip
          • V Offline
            Vicspa
            Nice Valero, any issues with tiling?, I know the pattern does not tile, and I've been meaning to make one that does.
            • olisheaO Offline
              olishea
              offset your texture in photoshop down the middle πŸ˜‰ you can see seam in the bump
              oli
              • V Offline
                Vicspa
                The problem with that Olishea is that the linear pattern does not match from one side to the other, it's slightly offset, but it can be done with a little more work in PS.
                • olisheaO Offline
                  olishea
                  Yes, exactly. You are about to make a horizontally seamless texture. πŸ‘
                  oli
                  • V Offline
                    Vicspa
                    Here's one that tiles Ok.
                    • massimoM Offline
                      massimo Moderator
                      For this kind of images this little plugin called "tiler" for PS works pretty well (scroll to the bottom of the page). It works also in an image editor like Xnview for example.
                      • V Offline
                        valerostudio
                        I had already fixed the tiling issue with the vismat I attached.
                        • olisheaO Offline
                          olishea
                          Sorry it must have been subdivisions that gave the texture the appearance of being tiled.
                          I was gonna upload my own scratchmap, but nobody would learn anything.
                          Your material is very close, I just believe it needs more reflection to match the photograph you posted. Can you also reduce the blurriness of the reflection in Vray?
                          Basically, the longer you polish stainless steel; the shinier it gets and the bump is reduced.
                          So low polish=high bump low shine. High polish=low bump more shine. πŸ‘
                          It's a very tricky material to achieve....especially as there are so many grades of stainless steel. πŸ˜†
                          oli
                          • V Offline
                            Vicspa
                            Grazie Massimo, I will try it out.
                            Will also try the plugin just below the tiler one called "Ultimate Artist Aggravator"
                            • massimoM Offline
                              massimo Moderator
                              πŸ˜‰
