    Stainless Steel
    renderpluginsextensions
    19 Posts 6 Posters 6.4k Views 6 Watching
    • V Offline
      valerostudio
      Thanks Andy!
      • V Offline
        valerostudio
        Any chance of getting you to share that map? πŸ’š
        • V Offline
          Vicspa
          Her's a couple I had made for myself, hope it helps.
          • olisheaO Offline
            olishea
            Nice. These will surely add to the realism, especially the second one.
            There is also a scratchmap on the Twilight Render forum resources.
            The material andybot posted is very close but needs the scratches from the polishing technique. Some more reflection/fresnel would also look better. Saying that it all depends which grade of stainless steel you choose! πŸ˜‰
            oli
            • olisheaO Offline
              olishea
              Tip:
              You can make a stainless steel bumpmap by stretching a noise texture. A scratchmap.
              Go to photoshop. Start with a white canvas and Add Noise. Make sure to check Monochrome.
              Now apply the rain filter which will stretch your Noise Map. Use Free Transform to stretch it even more.
              You can now change the levels/contrast to make the bumps deeper/lighter.
              Stainless Steel gets that sheen on its surface from the manufacturing technique....spinning and polishing. Spun stainless ALWAYS has horizontal polish lines (your new bumpmap/scratchmap).
              See these old threads of mine, it's twilight render but you will see how the bump makes the sheen and will translate into Vray.
              http://i654.photobucket.com/albums/uu269/olishea/orb_high.jpg
              http://sketchucation.com/forums/viewtopic.php?f=81&t=28990
              the material discussion on the twilight render forum:
              http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1720&p=13968#p13968
              oli
              • soloS Offline
                This is where procedural maps come in handy
                • V Offline
                  valerostudio
                  I took Vicspa's 02 map and adjusted it to be horizontally tileable and make a reflection map from it. Tweaked a few settings from the suggestions here and I think I got something worthwhile. Add bump for closeups and turn down the subdivs to reduce render times.
                  Valero_Stainless.zip
                  • V Offline
                    Vicspa
                    Nice Valero, any issues with tiling?, I know the pattern does not tile, and I've been meaning to make one that does.
                    • olisheaO Offline
                      olishea
                      offset your texture in photoshop down the middle πŸ˜‰ you can see seam in the bump
                      oli
                      • V Offline
                        Vicspa
                        The problem with that Olishea is that the linear pattern does not match from one side to the other, it's slightly offset, but it can be done with a little more work in PS.
                        • olisheaO Offline
                          olishea
                          Yes, exactly. You are about to make a horizontally seamless texture. πŸ‘
                          oli
                          • V Offline
                            Vicspa
                            Here's one that tiles Ok.
                            • massimoM Offline
                              massimo Moderator
                              For this kind of images this little plugin called "tiler" for PS works pretty well (scroll to the bottom of the page). It works also in an image editor like Xnview for example.
                              • V Offline
                                valerostudio
                                I had already fixed the tiling issue with the vismat I attached.
                                • olisheaO Offline
                                  olishea
                                  Sorry it must have been subdivisions that gave the texture the appearance of being tiled.
                                  I was gonna upload my own scratchmap, but nobody would learn anything.
                                  Your material is very close, I just believe it needs more reflection to match the photograph you posted. Can you also reduce the blurriness of the reflection in Vray?
                                  Basically, the longer you polish stainless steel; the shinier it gets and the bump is reduced.
                                  So low polish=high bump low shine. High polish=low bump more shine. πŸ‘
                                  It's a very tricky material to achieve....especially as there are so many grades of stainless steel. πŸ˜†
                                  oli
                                  • V Offline
                                    Vicspa
                                    Grazie Massimo, I will try it out.
                                    Will also try the plugin just below the tiler one called "Ultimate Artist Aggravator"
                                    • massimoM Offline
                                      massimo Moderator
                                      πŸ˜‰
