    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 526.5k Views 102 Watching
      shri
      many many thanks for your great tool.. πŸ‘
      • majidM Offline
        majid
        unique genius Fredeo!!!!! many many thank you, this is greaaat
        • pietervP Offline
          pieterv
          Hey Fredo,
          Thanks a lot for the great plugin! You are a hero.
          I have a slight problem tho. I used your plugin and in sketchup it looks like this
          http://www.citypixels.be/wp-content/uploads/2012/10/sketchup-thrupaint-01.png
          but when I render it in Maxwell Render it looks like this:
          http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-017.jpg
          The yellow stones in the little wall have become much smaller and the middle part of the street has become darker. Do you have an idea what the problem could be?
          Pieter
          This is my website:
          Citypixels - 3d Visualisatie Architectuur
            Check if the two surfaces have the material applied in a different way.
            I suspect that one has the material applied to the face itself while the other has the material applied to the 'container' [group/component-instance] - check this by using 'Entity Info' and selecting the actual faces in each case - the 'mapping' cannot persist into exported formats when applied to a container rather than the face itself... Of course it might be a Maxwell issue with it mis-handing the UVmapping ?
              Contact Maxwell support - as this is their render engine that doesn't properly process the UV mapping.
              • pietervP Offline
                pieterv
                I have checked, and the two materials are axactly the same. I have the free version of Maxwell Render, so I'll repost this under "extensions & applications". Thanks for answering!
                This is my website:
                  I'd still recommend you contact Maxwell - as this would then be something that presumably affects all users. Reporting issues to the developers is important - otherwise it'll never get fixed.
                    cadmunkey
                    Is this plugin for premium members only? If I click the download icon I get a banner.png.
                    • massimoM Offline
                      massimo Moderator
                      ThruPaint is installed as part of FredoTools.. It requires LibFredo6 4.4 or above.
                      See the main post for this plugin for Installation of FredoTools
                      So you have to go to Fredo tools thread to download the plugin. Scroll down the page and you'll find it below the "download" icon.
                        cadmunkey
                        Cheers!
                        • masterpaulM Offline
                          masterpaul
                          I cant seem to texture this irregular surface, it just wont do it, textures wont align no matter what, and they also rotated differently everywhere.
                          Edit: Uploaded the file also.
                          Trickeywall.skp
                          • fredo6F Offline
                            The surafce is very 'irregular' actually. Unless it is made of Quads (with Thomthom's convention), I am afraid it cannot be properly mapped with ThruPaint.
                            I would recommend you try with SketchUV plugin, which is more specialized in UV-mapping any kind of surface.
                              masterpaul
                              Thanks πŸ˜„
                              • OxerO Offline
                                Oxer
                                Hi Fredo,
                                I'm user of Thea4SU plugin and I have found a conflict with your plugin, before to install Thea4SU, ThruPaint worked fine but after, it appears this Error in Ruby Console:
                                I don't know if you can help me, I'll comment it to Tomasz (plugin developer) too.
                                • fredo6F Offline
                                  Oxer,
                                  Thanks for signaling.
                                  Could you type the following in the Ruby console and send me the output
                                  Sketchup.read_default "FredoTools_ThruPaint", "Param"
                                  • OxerO Offline
                                    Oxer
                                    This is the output in Ruby Console:
                                    • fredo6F Offline
                                      Oxer,
                                      Thanks. Did you type the command with Thea installed or uninstalled (because the string is correct)?
                                      • OxerO Offline
                                        Oxer
                                        With Thea installed, I probed to type the command before and after to use Thea4SU and the result in the ruby console is the same.
                                          Perhaps Thea uses a materials-observer and that then clashes with how this Fredo tool works ?
                                          Other renderers like Twilight probably have something similar too, without clashing; so it will be fixable, but then that's probably needed on the Thea side...
                                            Many render engines has a tendency to cause instability due to observers. Now, I do think ThruPaint also uses some observers. It's not easy to work out where the conflict lies when most render engines scramble their files (understandably).
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 17 / 17
