    [Plugin] Normal Map Maker
    43 Posts 21 Posters 61.2k Views 21 Watching
    • T
      tspco
      I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        RepulsiveBoy
        It doesn't work for me either 😒
          driven
          hi, did you look in the right place?
          UI.menu("File").add_item("Export normal map")
            Didier's version says this quite clearly
            You'll find the command under the **File** menu -> Export normal map
            πŸ˜’
            • T
              Tuttlet
              Great to find this Normal Map script. Thanks.
              I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
              Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
              http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
              http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
              • GaieusG
                You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
                • Bob JamesB
                  Bob James
                  Just browsing through, got interested, and don't understand your reply.
                  project (from what onto to what?) a greyscale image from one side (of what?)
                  export an image from the other side (of what?)
                  • T
                    Tuttlet
                    I believe this is the procedure:
                    1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                    2. Make the texture a projection
                    3. Select and apply the texture to the model
                    4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                    5. With a parallel projection and no edges, the top view is your bump map
                      You can do the same without a texture, use white Fog on black geometry.
                      • T
                        Tuttlet
                        Hey, that's even easier. Thanks.
                        But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                          Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                          • sicksickisckS
                            sicksickisck
                            great plugin and real deserves to update :]
                            ideas ;]
                            -read well smoothing groups!
                            -Z-grab [without the need of the selection of the polygons; works with components and groups]
                            • AO version hehe [dream:p]
                            • V
                              v66995
                              May i ask if this works on Sketchup 2015(i am using window 10)?
                              I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                              Then i select everything?->extension->Normal map maker-> export
                              After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                              I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                              It didn't work. did i do anything wrong or ?
                              Please help /_\ ....
                              Thanks all..
                              Vic.
                              • pbacotP
                                You need some surfaces visible from above which are NOT perpendicular to the camera view.
                                • JQLJ
                                  JQL
                                  Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                                  You should slitghtly taper your shape into truncated piramidal shapes.
                                  www.casca.pt
                                  Visit us on facebook!
                                  • V
                                    v66995
                                    Ohh ok ! i got it !
                                    Thank you so much Pbacot and JQL for the help !
                                    • 2 / 3
