    [Plugin] Normal Map Maker
    43 Posts 21 Posters 62.3k Views 21 Watching
    • Bob JamesB
      Bob James
      Just browsing through, got interested, and don't understand your reply.
      @gaieus said:
      You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
      project (from what onto to what?) a greyscale image from one side (of what?)
      export an image from the other side (of what?)
      • T
        Tuttlet
        I believe this is the procedure:
        1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
        2. Make the texture a projection
        3. Select and apply the texture to the model
        4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
        5. With a parallel projection and no edges, the top view is your bump map
          You can do the same without a texture, use white Fog on black geometry.
          • T
            Tuttlet
            Hey, that's even easier. Thanks.
            But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
              Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
              • sicksickisckS
                sicksickisck
                great plugin and real deserves to update :]
                ideas ;]
                -read well smoothing groups!
                -Z-grab [without the need of the selection of the polygons; works with components and groups]
                • AO version hehe [dream:p]
                • V
                  v66995
                  May i ask if this works on Sketchup 2015(i am using window 10)?
                  I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                  Then i select everything?->extension->Normal map maker-> export
                  After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                  I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                  It didn't work. did i do anything wrong or ?
                  Please help /_\ ....
                  Thanks all..
                  Vic.
                  • pbacotP
                    You need some surfaces visible from above which are NOT perpendicular to the camera view.
                    • JQLJ
                      JQL
                      Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                      You should slitghtly taper your shape into truncated piramidal shapes.
                      www.casca.pt
                      Visit us on facebook!
                      • V
                        v66995
                        Ohh ok ! i got it !
                        Thank you so much Pbacot and JQL for the help !
                        • 3 / 3
