    [Plugin] Normal Map Maker
    43 Posts 21 Posters 62.3k Views 21 Watching
    • PixeroP
      Pixero
      @aceshigh said:
      1 - whats the advantage of normal map over bump and displacement maps (both of which can use the same grayscale bitmap)?
      A bumpmap is like: Hey, change your normal (surface direction) by this grayscale amount!
      A normal map is more like: Yo, use this normal instead of your old one!
      • T
        tspco
        I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          RepulsiveBoy
          It doesn't work for me either 😒
            driven
            hi, did you look in the right place?
            UI.menu("File").add_item("Export normal map")
              Didier's version says this quite clearly
              You'll find the command under the **File** menu -> Export normal map
              πŸ˜’
              • T
                Tuttlet
                Great to find this Normal Map script. Thanks.
                I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
                Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
                http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
                http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
                • GaieusG
                  You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
                  • Bob JamesB
                    Bob James
                    Just browsing through, got interested, and don't understand your reply.
                    project (from what onto to what?) a greyscale image from one side (of what?)
                    export an image from the other side (of what?)
                    • T
                      Tuttlet
                      I believe this is the procedure:
                      1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                      2. Make the texture a projection
                      3. Select and apply the texture to the model
                      4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                      5. With a parallel projection and no edges, the top view is your bump map
                        You can do the same without a texture, use white Fog on black geometry.
                        • T
                          Tuttlet
                          Hey, that's even easier. Thanks.
                          But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                            Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                            • sicksickisckS
                              sicksickisck
                              great plugin and real deserves to update :]
                              ideas ;]
                              -read well smoothing groups!
                              -Z-grab [without the need of the selection of the polygons; works with components and groups]
                              • AO version hehe [dream:p]
                              • V
                                v66995
                                May i ask if this works on Sketchup 2015(i am using window 10)?
                                I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                                Then i select everything?->extension->Normal map maker-> export
                                After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                                I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                                It didn't work. did i do anything wrong or ?
                                Please help /_\ ....
                                Thanks all..
                                Vic.
                                • pbacotP
                                  You need some surfaces visible from above which are NOT perpendicular to the camera view.
                                  • JQLJ
                                    JQL
                                    Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                                    You should slitghtly taper your shape into truncated piramidal shapes.
                                    www.casca.pt
                                    Visit us on facebook!
                                    • V
                                      v66995
                                      Ohh ok ! i got it !
                                      Thank you so much Pbacot and JQL for the help !
                                      • 2 / 3
