    [Plugin] Normal Map Maker
    43 Posts 21 Posters 62.3k Views 21 Watching
      RepulsiveBoy
      @tspco said:
      I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
      It doesn't work for me either 😒
        driven
        hi, did you look in the right place?
        UI.menu("File").add_item("Export normal map")
          Didier's version says this quite clearly
          You'll find the command under the **File** menu -> Export normal map
          πŸ˜’
          • T
            Tuttlet
            Great to find this Normal Map script. Thanks.
            I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
            Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
            http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
            http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
            • GaieusG
              You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
              • Bob JamesB
                Bob James
                Just browsing through, got interested, and don't understand your reply.
                project (from what onto to what?) a greyscale image from one side (of what?)
                export an image from the other side (of what?)
                • T
                  Tuttlet
                  I believe this is the procedure:
                  1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                  2. Make the texture a projection
                  3. Select and apply the texture to the model
                  4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                  5. With a parallel projection and no edges, the top view is your bump map
                    You can do the same without a texture, use white Fog on black geometry.
                    • T
                      Tuttlet
                      Hey, that's even easier. Thanks.
                      But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                        Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                        • sicksickisckS
                          sicksickisck
                          great plugin and real deserves to update :]
                          ideas ;]
                          -read well smoothing groups!
                          -Z-grab [without the need of the selection of the polygons; works with components and groups]
                          • AO version hehe [dream:p]
                          • V
                            v66995
                            May i ask if this works on Sketchup 2015(i am using window 10)?
                            I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                            Then i select everything?->extension->Normal map maker-> export
                            After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                            I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                            It didn't work. did i do anything wrong or ?
                            Please help /_\ ....
                            Thanks all..
                            Vic.
                            • pbacotP
                              You need some surfaces visible from above which are NOT perpendicular to the camera view.
                              • JQLJ
                                JQL
                                Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                                You should slitghtly taper your shape into truncated piramidal shapes.
                                www.casca.pt
                                Visit us on facebook!
                                • V
                                  v66995
                                  Ohh ok ! i got it !
                                  Thank you so much Pbacot and JQL for the help !
                                  • 2 / 3
