    [Plugin] Normal Map Maker
    43 Posts 21 Posters 62.3k Views 21 Watching
    • T
      tomasz
      @tig said:
      The main issue is how do I tell if a face's material's texture is 'distorted' and needs this extra step... πŸ˜•
      It would greatly improve my OBJexporter and some 3rd party tools I am involved with...
      http://forums.sketchucation.com/viewtopic.php?f=180&t=23947&hilit=distorted&start=60#p204899
      • PixeroP
        Pixero
        @aceshigh said:
        1 - whats the advantage of normal map over bump and displacement maps (both of which can use the same grayscale bitmap)?
        A bumpmap is like: Hey, change your normal (surface direction) by this grayscale amount!
        A normal map is more like: Yo, use this normal instead of your old one!
        • T
          tspco
          I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
          SU make 2017, /Twilight Render Hobby
          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
            RepulsiveBoy
            It doesn't work for me either 😒
              driven
              hi, did you look in the right place?
              UI.menu("File").add_item("Export normal map")
                Didier's version says this quite clearly
                You'll find the command under the **File** menu -> Export normal map
                πŸ˜’
                • T
                  Tuttlet
                  Great to find this Normal Map script. Thanks.
                  I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
                  Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
                  • GaieusG
                    You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
                    • Bob JamesB
                      Bob James
                      Just browsing through, got interested, and don't understand your reply.
                      project (from what onto to what?) a greyscale image from one side (of what?)
                      export an image from the other side (of what?)
                      • T
                        Tuttlet
                        I believe this is the procedure:
                        1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                        2. Make the texture a projection
                        3. Select and apply the texture to the model
                        4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                        5. With a parallel projection and no edges, the top view is your bump map
                          You can do the same without a texture, use white Fog on black geometry.
                          • T
                            Tuttlet
                            Hey, that's even easier. Thanks.
                            But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                              Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                              • sicksickisckS
                                sicksickisck
                                great plugin and real deserves to update :]
                                ideas ;]
                                -read well smoothing groups!
                                -Z-grab [without the need of the selection of the polygons; works with components and groups]
                                • AO version hehe [dream:p]
                                • V
                                  v66995
                                  May i ask if this works on Sketchup 2015(i am using window 10)?
                                  I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                                  Then i select everything?->extension->Normal map maker-> export
                                  After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                                  I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                                  It didn't work. did i do anything wrong or ?
                                  Please help /_\ ....
                                  Thanks all..
                                  Vic.
                                  • pbacotP
                                    You need some surfaces visible from above which are NOT perpendicular to the camera view.
                                    • JQLJ
                                      JQL
                                      Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                                      You should slitghtly taper your shape into truncated piramidal shapes.
                                      www.casca.pt
                                      Visit us on facebook!
                                      • V
                                        v66995
                                        Ohh ok ! i got it !
                                        Thank you so much Pbacot and JQL for the help !
                                        • 2 / 3
