    [Plugin] Normal Map Maker
    43 Posts 21 Posters 62.3k Views 21 Watching
    • T
      Tuttlet
      Great to find this Normal Map script. Thanks.
      I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
      Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
      http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
      http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
      • GaieusG
        You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
        • Bob JamesB
          Bob James
          Just browsing through, got interested, and don't understand your reply.
          project (from what onto to what?) a greyscale image from one side (of what?)
          export an image from the other side (of what?)
          • T
            Tuttlet
            I believe this is the procedure:
            1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
            2. Make the texture a projection
            3. Select and apply the texture to the model
            4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
            5. With a parallel projection and no edges, the top view is your bump map
              You can do the same without a texture, use white Fog on black geometry.
              • T
                Tuttlet
                Hey, that's even easier. Thanks.
                But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                  Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                  • sicksickisckS
                    sicksickisck
                    great plugin and real deserves to update :]
                    ideas ;]
                    -read well smoothing groups!
                    -Z-grab [without the need of the selection of the polygons; works with components and groups]
                    • AO version hehe [dream:p]
                    • V
                      v66995
                      May i ask if this works on Sketchup 2015(i am using window 10)?
                      I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                      Then i select everything?->extension->Normal map maker-> export
                      After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                      I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                      It didn't work. did i do anything wrong or ?
                      Please help /_\ ....
                      Thanks all..
                      Vic.
                      • pbacotP
                        You need some surfaces visible from above which are NOT perpendicular to the camera view.
                        • JQLJ
                          JQL
                          Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
                          You should slitghtly taper your shape into truncated piramidal shapes.
                          www.casca.pt
                          Visit us on facebook!
                          • V
                            v66995
                            Ohh ok ! i got it !
                            Thank you so much Pbacot and JQL for the help !
                            • 3 / 3
