    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      d12dozr
      Sweet update...Thanks, Fredo! πŸ‘ ...and Jeff for the inspiration πŸ˜„
      http://goo.gl/f7ooYh
        Daniel S
        Great Update Fredo!!! 😍 😍 😍
        I remember a lot this request...
        http://forums.sketchucation.com/viewtopic.php?f=180&t=24831
        I just tried your plugin and I had perfect results in seconds!!
        Thank you for making a much more powerful Sketchup Fredo!!!
        Daniel S
        • fredo6F Offline
          NEW FEATURES: with LibFredo6 4.5- 08 May 12
          If you upgrade to LibFredo6 4.5, you will get two new features for the Free Rotate tool (and other tools based on rotation such as Box Rotate, Twist, Free Planar Shearing).
          These new functions are largely inspired from Jeff Hammond's mini-challenge.
          1. Rotate with Offset
            In the SU Rotate tool and previous versions of FredoScale Free Rotate, the inferences are only done about the base line of rotation. This makes difficult to perform rotation when the target point to infer is not on the base line.
            In the new version of Free Rotate, there is an extra step where you can select a target line at a certain offset to be used for inference. This is shown on the video below.
          Note that this step is proposed by default in Free Rotate (just click again if you don't need it) and as an option for other tools (via a long click).
          1. Inference on line
            The typical situation is to rotate a line until it exactly touches another line. This is a typical limitation of the SU Rotate tool which does not provide inference for this case.
            Free Rotate now proposes this inference.
            This is an old request from Daniel S, also mentioned by Jeff in his mini-challenge.
          Please see this post for downloading the latest version of LibFredo6.
          • W Offline
            Wong CK
            Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... 😒
              Have you got the supporting 'Fredo Lib' file/subfolder downloaded/installed as explained on the download page ?
              Have you activated the tool under Window > Preferences > Extensions > FredoScale ?
              Have you then activated its toolbar from View > Toolbars > Fredo Scale ?
              Have you then got the menu item Tools > Fredo6 Collection > FredoScale ... ?
                redlerred7
                do you also have the Fredo file library, which has a link found in the first post, that you need to use the plugin?
                  kira
                  thank you
                    SnowTiger
                    This is an Excellent Plugin that I would recommend to anyone and everyone who might ever need to create organic shapes such as boat sails and/or tensile roof structures and the like.
                    It is extremely easy to use and works very well.
                    The fact that it is Free is also amazing because it certainly does have value and will save you tons of time regardless what you are trying to create with it.
                    Thanks again so much for sharing this excellent Plugin as well as for continuing to make improvements/updates.
                      sags
                      thanks...This is an Excellent Plugin. πŸ‘
                        Rosta
                        what should I do - look at the attachment, thanks for an answer
                        after  the start of SketchUp
                          Looks like a bad install.
                          Show us a screen shot of your Plugins folder as well as one showing the contents of the folder called FREDOSCALE_Dir_22. It appears you haven't got _loader.rb inside that folder. If you didn't get that one in there, you probably have others you didn't get in there, too. Follow the instructions in the first post of this thread and take a look at the sticky post about installing zipped plugins.
                            Rosta
                            Thanks, I did a new install and now it is ok. But I have another problem. I'd like to have Toolbar of FredoScale. I have the check of FredoScale ON in View -> Toolbars but I have nothing. Thanks
                              Perhaps your install still isn't correct. Did the toolbar icons get extracted to the right folder? Did you check the box for FredoScale under Extensions?
                                Rosta
                                I am a beginner for setup of SU. I do know what I did but now I have everything. Thanksssss
                                  Kgon
                                  Hi there guys.
                                  Well i'm having some problems with this set of tools...mainly with the twisting tool...everything seems fine 'till i give the last click to finish the "command"...immediately i get a bugsplat, no matter the shape even with a single cube it crashes 😒 . Im using sketchup 8 and windows 7 64 bit.
                                  Any clue? Thanks in advise
                                  • fredo6F Offline
                                    @kgon said:
                                    Hi there guys.
                                    It may come from a conflict with another plugin: Podium (some versions), Matchbox, Sun Position, may be others.
                                    Did you try the Bend functions and do you get a bugsplat too.
                                      Maybe you must post some file skp for more helps πŸ˜„ (save as V6)
                                      And one image before / after πŸ˜„
                                        alexpacio
                                        few days is that I do not work anymore fredoscale.
                                        fredoscale using the center of the object (CTRL), I scale the entire object and not expanding the center.
                                        What has happened?
                                        What should I change?
                                        thanks
                                        Solved.
                                        Updated files and everything ok
                                        thanks anyway 😍 😍 😍
                                          alexpacio
                                          My screen capture
                                          https://www.dropbox.com/s/hvahftfqaf3d6f6/scale 1.jpg
                                          https://www.dropbox.com/s/68rq6gsyc26plhy/Scale 1b.jpg
                                          https://www.dropbox.com/s/fae0p3kc5p46tuf/Scale 2.jpg
                                          not scale
                                          final result
                                            Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 56
                                            • 57
                                            • 43 / 57
