    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Rosta
      what should I do - look at the attachment, thanks for an answer
      after  the start of SketchUp
        Looks like a bad install.
        Show us a screen shot of your Plugins folder as well as one showing the contents of the folder called FREDOSCALE_Dir_22. It appears you haven't got _loader.rb inside that folder. If you didn't get that one in there, you probably have others you didn't get in there, too. Follow the instructions in the first post of this thread and take a look at the sticky post about installing zipped plugins.
          Rosta
          Thanks, I did a new install and now it is ok. But I have another problem. I'd like to have Toolbar of FredoScale. I have the check of FredoScale ON in View -> Toolbars but I have nothing. Thanks
            Perhaps your install still isn't correct. Did the toolbar icons get extracted to the right folder? Did you check the box for FredoScale under Extensions?
              Rosta
              I am a beginner for setup of SU. I do know what I did but now I have everything. Thanksssss
              • K
                Kgon
                Hi there guys.
                Well i'm having some problems with this set of tools...mainly with the twisting tool...everything seems fine 'till i give the last click to finish the "command"...immediately i get a bugsplat, no matter the shape even with a single cube it crashes 😒 . Im using sketchup 8 and windows 7 64 bit.
                Any clue? Thanks in advise
                • fredo6F
                  @kgon said:
                  Hi there guys.
                  It may come from a conflict with another plugin: Podium (some versions), Matchbox, Sun Position, may be others.
                  Did you try the Bend functions and do you get a bugsplat too.
                    Maybe you must post some file skp for more helps πŸ˜„ (save as V6)
                    And one image before / after πŸ˜„
                      alexpacio
                      few days is that I do not work anymore fredoscale.
                      fredoscale using the center of the object (CTRL), I scale the entire object and not expanding the center.
                      What has happened?
                      What should I change?
                      thanks
                      Solved.
                      Updated files and everything ok
                      thanks anyway 😍 😍 😍
                        alexpacio
                        My screen capture
                        https://www.dropbox.com/s/hvahftfqaf3d6f6/scale 1.jpg
                        https://www.dropbox.com/s/68rq6gsyc26plhy/Scale 1b.jpg
                        https://www.dropbox.com/s/fae0p3kc5p46tuf/Scale 2.jpg
                        not scale
                        final result
                        • GaieusG
                          Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
                            alexpacio
                            Sorry,
                            I solved it.
                            I reinstalled and fredoscale libfredo and now everything is ok.
                            Thanks anyway. πŸ‘ πŸ‘
                            compliments for the speed of responses. This forum is a really quick. πŸ˜„ πŸ˜„
                            sorry for my English (using Google translate) but my only language is Italian. πŸ‘Š πŸ‘Š
                            • GaieusG
                              We have an Italian subforum at the bottom (I have added you now). It's not the busiest forum but still, if you get stuck, there are a couple of Italians here...
                                alfabenedict
                                Thank you! This SketchUp Bending rocks! 😎
                                • L
                                  local
                                  Hi!
                                  I have a little problem with this plugin. If the stretching device provided by the component or group, then the attribute does not change the size.
                                  Sorry, this turned out to google.
                                    I think I understand what you wrote, local, but it isn't entirely clear.
                                    It is true that if you stretch a component or group, you only change the appearance of that entity but it doesn't change the definition not does it change any other instances of the component in the model. This happens with the native Scale tool as well. To change the definition (attributes) you need to open the component or group for editing and modify the geometry inside.
                                      Could it be that he's referring to Dynamic Components?
                                      • L
                                        local
                                        This component consists of several group.
                                        • pbacotP
                                          I am not sure of the question but the stretching tool alters the component itself,unlike the scale tool.
                                          If more than one instance of the component is in drawing, stretching creates a new component definition--so the original component is unchanged.
                                          • pjbazelP
                                            pjbazel
                                            Hello all,
                                            This is my first post, but I have spent countless hours reading this forum and it has been the the most amazing SU resource. Im just learning, and I would have a fraction of my current knowledge/ability without this forum, not to mention the developers who make scripts for SU (thank you Fredo!!!) Im amazed how much effort and energy the individuals in this community are willing to give. Truly amazing!
                                            I now have my first question, or at least a question I could not answer simply by reading. I tried to search for the answer, I did not find it, but im sure its simple.
                                            Using Fredo scale box scaling, when I grab/drag a handle and scale it jumps from 1.0 to 1.05, and I can not get it to scale in this range (1.0-1.05) without typing the values. It would be very nice to stop this, and have it scale in this range without it jumping from 1.0 to 1.05.
                                            Is there a way to change this?
                                            thanks...
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 58
                                            • 59
                                            • 36 / 59
