    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
    • W
      Wong CK
      Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... 😒
        Have you got the supporting 'Fredo Lib' file/subfolder downloaded/installed as explained on the download page ?
        Have you activated the tool under Window > Preferences > Extensions > FredoScale ?
        Have you then activated its toolbar from View > Toolbars > Fredo Scale ?
        Have you then got the menu item Tools > Fredo6 Collection > FredoScale ... ?
          redlerred7
          do you also have the Fredo file library, which has a link found in the first post, that you need to use the plugin?
          • K
            kira
            thank you
              SnowTiger
              This is an Excellent Plugin that I would recommend to anyone and everyone who might ever need to create organic shapes such as boat sails and/or tensile roof structures and the like.
              It is extremely easy to use and works very well.
              The fact that it is Free is also amazing because it certainly does have value and will save you tons of time regardless what you are trying to create with it.
              Thanks again so much for sharing this excellent Plugin as well as for continuing to make improvements/updates.
                sags
                thanks...This is an Excellent Plugin. πŸ‘
                  Rosta
                  what should I do - look at the attachment, thanks for an answer
                  after  the start of SketchUp
                    Looks like a bad install.
                    Show us a screen shot of your Plugins folder as well as one showing the contents of the folder called FREDOSCALE_Dir_22. It appears you haven't got _loader.rb inside that folder. If you didn't get that one in there, you probably have others you didn't get in there, too. Follow the instructions in the first post of this thread and take a look at the sticky post about installing zipped plugins.
                      Rosta
                      Thanks, I did a new install and now it is ok. But I have another problem. I'd like to have Toolbar of FredoScale. I have the check of FredoScale ON in View -> Toolbars but I have nothing. Thanks
                        Perhaps your install still isn't correct. Did the toolbar icons get extracted to the right folder? Did you check the box for FredoScale under Extensions?
                          Rosta
                          I am a beginner for setup of SU. I do know what I did but now I have everything. Thanksssss
                          • K
                            Kgon
                            Hi there guys.
                            Well i'm having some problems with this set of tools...mainly with the twisting tool...everything seems fine 'till i give the last click to finish the "command"...immediately i get a bugsplat, no matter the shape even with a single cube it crashes 😒 . Im using sketchup 8 and windows 7 64 bit.
                            Any clue? Thanks in advise
                            • fredo6F
                              @kgon said:
                              Hi there guys.
                              It may come from a conflict with another plugin: Podium (some versions), Matchbox, Sun Position, may be others.
                              Did you try the Bend functions and do you get a bugsplat too.
                                Maybe you must post some file skp for more helps πŸ˜„ (save as V6)
                                And one image before / after πŸ˜„
                                  alexpacio
                                  few days is that I do not work anymore fredoscale.
                                  fredoscale using the center of the object (CTRL), I scale the entire object and not expanding the center.
                                  What has happened?
                                  What should I change?
                                  thanks
                                  Solved.
                                  Updated files and everything ok
                                  thanks anyway 😍 😍 😍
                                    alexpacio
                                    My screen capture
                                    https://www.dropbox.com/s/hvahftfqaf3d6f6/scale 1.jpg
                                    https://www.dropbox.com/s/68rq6gsyc26plhy/Scale 1b.jpg
                                    https://www.dropbox.com/s/fae0p3kc5p46tuf/Scale 2.jpg
                                    not scale
                                    final result
                                    • GaieusG
                                      Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
                                        alexpacio
                                        Sorry,
                                        I solved it.
                                        I reinstalled and fredoscale libfredo and now everything is ok.
                                        Thanks anyway. πŸ‘ πŸ‘
                                        compliments for the speed of responses. This forum is a really quick. πŸ˜„ πŸ˜„
                                        sorry for my English (using Google translate) but my only language is Italian. πŸ‘Š πŸ‘Š
                                        • GaieusG
                                          We have an Italian subforum at the bottom (I have added you now). It's not the busiest forum but still, if you get stuck, there are a couple of Italians here...
                                            alfabenedict
                                            Thank you! This SketchUp Bending rocks! 😎
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 58
                                            • 59
                                            • 35 / 59
