    Mini-challenge
    328 Posts 26 Posters 42.8k Views 26 Watching
      Jason, how do you determine the where the diagonals hit the sides of the posts?
      Fredo's example does result in a narrower board. It could also be achieved with native tools by selecting one end of the board and moving that end up.
        If you measure .5m up and down the verticals, the board is not going to be .5m thick.
        • jason_marantoJ Offline
          jason_maranto
          The desired thickness is .5 meters -- so the first guides are each measured out to .5 meters from the main diagonal (the only one that is obvious and never changes).
          So the next Diagonal can be found at intersections at .5 m guide up on the left post and .5 m guide down on the right post -- from there you delete the original guides and connect the diagonals with the line tool.
          After that you pull off new guides to .5m from the bottom and top -- which again will give the corrected diagonal at the intersections on the left post and right post... the other diagonal has been known since the beginning(doesn't ever change).
          All I used was the line tool, tape measure tool, and push pull.
          Best,
          Jason.
          • fredo6F Offline
            @Fredo
            Is your frame changing thickness? It does for me
            Ooops. I should have read the thread in details.
            Then, it just need a dedicated plugin, this won't be a conform transformation
              jason_maranto
              It is as I show in the updated file.
              Best,
              Jason.
                A "plugin free" solution that is accurate to 0.009mm...
                DrawDiagonalRail.skp
                  No need to change anything! 😎
                  With the fredo scale πŸ˜‰
                  Just make the rotation on the top of the block! πŸ’­
                  [attachment=1:1hqifa7e]<!-- ia1 -->yes.jpg<!-- ia1 -->[/attachment:1hqifa7e]
                  [attachment=0:1hqifa7e]<!-- ia0 -->yes2.jpg<!-- ia0 -->[/attachment:1hqifa7e]
                  That changes the width of the board, doesn't it?
                    mac1
                      With the fredo scale Planar Shearing shown previus! πŸ˜‰
                      Perfect! πŸ‘
                        When testing I recommend you put the posts further apart as with near square shape deviances might be so small that you think you have a correct solution.
                          Mac1
                          How do you get the rotated guide pt to snap exactly onto the horizontal top guideline ?
                            No nothing is changed πŸ˜„
                            You have just to draw the block box to modify on the ground, with any measures (just fit the 2 pilars )
                            Nno need to push cut anything! πŸ‘
                              Pilou, when I used Fredo's method my board went from 5" wide to 3-1/16" wide. The length of the miter remained at 5", though. I'd say that's a change. Mac1's idea looks interesting.
                                Is this "close enough"?
                                PinkBoard-BlueBoard.skp
                                  jason_maranto
                                  Absolute accuracy seems to be something that would be pretty easy since we know all of the measurements, including the first diagonal -- I would just rotate a copy of the diagonal around the midpoint to make the second diagonal, thus giving all 4 ending points for the shape... but I would need to calculate the specific degrees for the rotation, and I'm not well versed in that level of math.
                                  Definitely seems a plugin to make this is a need after all... if absolute accuracy is required.
                                  Best,
                                  Jason.
                                    Very close - but surely it should be possible for full accuracy..?
                                      I also noticed that if I crank up the decimals, I get an inaccurate measurement for that thickness (although a different one) πŸ˜•
                                      Now the very interesting thing is that I did not do any shearing but only worked with the rotate tool. So there could be inaccuracy but then it's Sketchup's tolerance when it merged two endpoints so close that I could see the electrons spinning. But then yes, I was indeed relying on this "tolerance" (just did not know how it will work).
                                      • jeff hammondJ Offline
                                        @thomthom said:
                                        So how do you calculate it?
                                        the way i calculate it in the DC :
                                        you can find all the info of the hypotenuse (green) in a variety of ways .. (for instance, a^2 + b^2 = c^2 to get its length.. you'll know a & b in this case… then trig for the angles)
                                        that hypotenuse is also the the hypotenuse of the un-trimmed board (red).. so you know the board width and the length of its hypotenuse which means you can get all other angles and lengths..
                                        the rotation of the original hypotenuse minus the long angle of the board's hypotenuse give the correct rotation angle..
                                        here's the DC i use (after i use 'component options' to enter the dimension of height, board width, and the space in between the two poles, i'll then trace the results and copy/paste it into my actual drawing.. not entirely ideal but it works..)
                                        DC_Xbrace.skp
                                        for whatever reason, i still think there might be a way to do it in sketchup itself.. maybe jean L can come up with something πŸ˜‰
                                        so far, it's looking like true-tangents may be the key.. i haven't tried it yet in this circumstance but i imagine it will work.
                                          Excellent, Jeff.
                                          • pbacotP Offline
                                            @ecuadorian said:
                                            @andybot said:
                                            ... thus - for best accuracy, draw it in ACAD and import into sketchup πŸ˜’
                                            Amen. Trimble, if you're reading this, we need actual arcs and curves in SketchUp.
                                            i'm not quite sure they could give us true arcs in sketchup without entirely changing the way sketchup works.. (how would a cylinder be drawn if there were no segments in the arcs? a nurbs surface? )
                                            what they can give us, i feel, is 'guide arcs' …which would also allow us to rotate this thing and snap it into place very easily.
                                            Someone at Trimble is saying "What? There aren't real circles? Oh crap! What have we done?"
                                            • 16
                                            • 17
                                            • 4 / 17
