    Mini-challenge
    328 Posts 26 Posters 34.2k Views 26 Watching
    • fredo6F Offline
      Jeff,
      Not sure plugins are allowed in this challenge, and unless I am wrong, this could be done with the but normally Planar Shearing can be performed with FredoScale
        @Fredo
        Is your frame changing thickness? It does for me
        • jason_marantoJ Offline
          jason_maranto
          I got it accurate just using basic tools, but you have to do some contorting to get it done:(see this post for the file http://forums.sketchucation.com/viewtopic.php?p=401904#p401904)
          I misread the beginning of the thread and initially thought the dimensions were not important... which is why the first version did not achieve victory ๐Ÿ‘Š
          Best,
          Jason.
            A little light in my deseperation? ๐Ÿ˜„
            • pbacotP Offline
              [off:19rh2vop]
              The thing absolutly crazzy is that the Rotation tool
              seems accept just the base alignement as only good alignement! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
              I am totally depited! ๐Ÿ˜ฎ
              I love this word![/off:19rh2vop]
              Yes if heights are not a given... Push pull the posts to the diagonal ๐Ÿ’š
                Jason, how do you determine the where the diagonals hit the sides of the posts?
                Fredo's example does result in a narrower board. It could also be achieved with native tools by selecting one end of the board and moving that end up.
                  If you measure .5m up and down the verticals, the board is not going to be .5m thick.
                    jason_maranto
                    The desired thickness is .5 meters -- so the first guides are each measured out to .5 meters from the main diagonal (the only one that is obvious and never changes).
                    So the next Diagonal can be found at intersections at .5 m guide up on the left post and .5 m guide down on the right post -- from there you delete the original guides and connect the diagonals with the line tool.
                    After that you pull off new guides to .5m from the bottom and top -- which again will give the corrected diagonal at the intersections on the left post and right post... the other diagonal has been known since the beginning(doesn't ever change).
                    All I used was the line tool, tape measure tool, and push pull.
                    Best,
                    Jason.
                    • fredo6F Offline
                      @Fredo
                      Ooops. I should have read the thread in details.
                      Then, it just need a dedicated plugin, this won't be a conform transformation
                        jason_maranto
                        It is as I show in the updated file.
                        Best,
                        Jason.
                          A "plugin free" solution that is accurate to 0.009mm...
                          DrawDiagonalRail.skp
                            No need to change anything! ๐Ÿ˜Ž
                            With the fredo scale ๐Ÿ˜‰
                            Just make the rotation on the top of the block! ๐Ÿ’ญ
                            [attachment=1:1hqifa7e]<!-- ia1 -->yes.jpg<!-- ia1 -->[/attachment:1hqifa7e]
                            [attachment=0:1hqifa7e]<!-- ia0 -->yes2.jpg<!-- ia0 -->[/attachment:1hqifa7e]
                            That changes the width of the board, doesn't it?
                              mac1
                                With the fredo scale Planar Shearing shown previus! ๐Ÿ˜‰
                                Perfect! ๐Ÿ‘
                                  When testing I recommend you put the posts further apart as with near square shape deviances might be so small that you think you have a correct solution.
                                    Mac1
                                    How do you get the rotated guide pt to snap exactly onto the horizontal top guideline ?
                                      No nothing is changed ๐Ÿ˜„
                                      You have just to draw the block box to modify on the ground, with any measures (just fit the 2 pilars )
                                      Nno need to push cut anything! ๐Ÿ‘
                                        Pilou, when I used Fredo's method my board went from 5" wide to 3-1/16" wide. The length of the miter remained at 5", though. I'd say that's a change. Mac1's idea looks interesting.
                                          Is this "close enough"?
                                          PinkBoard-BlueBoard.skp
                                            jason_maranto
                                            Absolute accuracy seems to be something that would be pretty easy since we know all of the measurements, including the first diagonal -- I would just rotate a copy of the diagonal around the midpoint to make the second diagonal, thus giving all 4 ending points for the shape... but I would need to calculate the specific degrees for the rotation, and I'm not well versed in that level of math.
                                            Definitely seems a plugin to make this is a need after all... if absolute accuracy is required.
                                            Best,
                                            Jason.
                                            • 16
                                            • 17
                                            • 4 / 17
