    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 526.5k Views 102 Watching
    • KrisidiousK Offline
      Krisidious
      Remembering of last scaling and rotation factors by material.
      OH MY... AWESOMENESS....
      By: Kristoff Rand
        About the first option
        Yet existing for a multiple selection with normal use of SU?
          jorge2011
          fredo, thank you very much for this new update.
          A query. Is possible to copy the material properties (rotation, scale, etc ...) and paste those properties to other faces?
          • EarthMoverE Offline
            EarthMover
            Great update Fredo! This was my only issue with the tool. Now it is perfection!
            Content Creator at Skapeup
            • fredo6F Offline
              You have the transfer UV mode, which allows to substitute a texture by another without changing the UVs.
              Otherwise, if the faces are adjacent to the painted faces, just click and drag to extend the painting.
                If the mesh is made out of Quads you can use QuadFace Tools to copy and paste UV mapping.
                  jorge2011
                  thank you very much
                    jorge2011
                    can be applied a methodology similar to native sketchup materials, using the "Alt" to copy the properties of a material?
                    • fredo6F Offline
                      We cannot use ALT in scripts because when the key is UP it gives focus to the main Sketchup menu.
                      But I can do it on Shift
                      Note that you can also press the Enter key to sample the material under the mouse
                      • kenK Offline
                        ken
                        I have updated as required Fredo Tools to 1.1n and Thru:Paint to 1.0n, however the Check Plugin for Updates still list the two programs as Fredo Tools as 1.1m and Thru:Paint as 1.0m.
                        Am I making a mistake, or is the new programs not registering correctly?
                        Ken
                        • OxerO Offline
                          Oxer
                          Hi Fredo, i'm testing the last revision of ThruPaint 1.0n on Mac (OSX 10.6.8 & SU8) all works fine except that you say in the main post about Material Selector but i have found other problem the arrows don't work on Mac, it is not a big problem because i can introduce the values through the Measures or Visual Edition Mode.
                          Thanks for this great plugin!! πŸ‘
                          • fredo6F Offline
                            Oxer,
                            Did it work in previous versions?
                            Or other Mac OS versions?
                            • OxerO Offline
                              Oxer
                              Oxer,
                              No, it doesn't work in previous version.
                              I haven't probed other Mac OS versions.
                                Pherim
                                This is really great, thank you for fulfilling my request!
                                It works great, just how I wanted it to. [[Just one small thing: It would be perfect to me if the "sample material" tool could also adopt the scale of the sampled material.
                                I hope I don't bother you with my daydreams... πŸ˜’]] edit: never mind, it works perfectly! πŸ‘
                                • fredo6F Offline
                                  Oxer,
                                  Strange because it works for some other Mac users
                                  Could you type in the Ruby Console
                                  • VK_DOWN
                                  • VK_UP
                                  • VK_LEFT
                                  • VK_RIGHT
                                  • OxerO Offline
                                    Oxer
                                    This is the result in the Ruby Console:
                                      moghamdi
                                      Thank you Fredo for this nice Plugin.
                                      I have a problem
                                      I have a Mac 10.6.8 and I cannot transform the texture. I tried all 3 ways you mentioned but they did not work.
                                      • fredo6F Offline
                                        I have a problem
                                        Could you open the Ruby console and see if something is displayed.
                                        It seems that the Arrows don't work on all Mac, but the VCB and Visual Editor should normally function correctly.
                                        • fredo6F Offline
                                          [attachment=0:23qhhc8q]<!-- ia0 -->Ruby Console.jpg<!-- ia0 -->[/attachment:23qhhc8q]
                                          Oxer,
                                          Thanks. Interesting to see that the value may be different depending on the Mac versions (on the Mac I have access to, VK_DOWN = 63233
                                          Anyway, ThruPaint only use the symbolic constant value VK_DOWN and therefore should not be impacted by the internal value of the Arrows constants.
                                          It seems also that several Mac users don't have any problem with the Arrows on Mac.
                                          Just in case, could you type in the Ruby Console Traductor.new_check_key(VK_DOWN, 0, 0).
                                          Also, when you try to exercise transformation by arrows on texture, could you leave the Ruby console open to see if an error message is displayed. Also, make sure that the focus is on the Sketchup window when typing the arrows.
                                            In my scripts that use arrows keys I use this
                                            if RUBY_PLATFORM=~/mswin32/ ### PC
                                              KALXMINUS = 37          # Arrow Left Key
                                              KARXPLUS  = 39          # Arrow Right Key
                                              KAUYPLUS  = 38          # Arrow Up Key
                                              KADYMINUS = 40          # Arrow Down Key
                                              KSHIFT    = 16          # Shift Key
                                            else### MAC
                                              KALXMINUS = 63234       # Arrow Left Key
                                              KARXPLUS  = 63235       # Arrow Right Key
                                              KAUYPLUS  = 63232       # Arrow Up Key
                                              KADYMINUS = 63233       # Arrow Down Key
                                              KSHIFT    = 131072      # Shift Key
                                            end#if
                                            and then test key-down events etc against these 'constants'
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
