    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 610.7k Views 102 Watching
    • C
      cmoreink
      Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him πŸ˜‰
      my portfolio
      • pep75P
        pep75
        Jiiiiiihhhaaaaaaaaaaaaaaa!!!!!!! 😳
        • P
          Pherim
          Played around with it for quite some time now and still I am amazed about what this plugin can do.
          If I may ask, would it be possible to add an option that allows to chose the scale of the texture before applying it and then keep that value until it is changed? That would save a lot of time in comparison to changing the scale of each texture manually after it was applied.
          • fredo6F
            That's a good idea, but I would put it as an option.
            Note you can also change the material definition (i.e. the dimensions).
            • P
              Pherim
              Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
              • KrisidiousK
                Krisidious
                Remembering of last scaling and rotation factors by material.
                OH MY... AWESOMENESS....
                By: Kristoff Rand
                  About the first option
                  Yet existing for a multiple selection with normal use of SU?
                    jorge2011
                    fredo, thank you very much for this new update.
                    A query. Is possible to copy the material properties (rotation, scale, etc ...) and paste those properties to other faces?
                    • EarthMoverE
                      EarthMover
                      Great update Fredo! This was my only issue with the tool. Now it is perfection!
                      Content Creator at Skapeup
                      • fredo6F
                        You have the transfer UV mode, which allows to substitute a texture by another without changing the UVs.
                        Otherwise, if the faces are adjacent to the painted faces, just click and drag to extend the painting.
                          If the mesh is made out of Quads you can use QuadFace Tools to copy and paste UV mapping.
                            jorge2011
                            thank you very much
                              jorge2011
                              can be applied a methodology similar to native sketchup materials, using the "Alt" to copy the properties of a material?
                              • fredo6F
                                We cannot use ALT in scripts because when the key is UP it gives focus to the main Sketchup menu.
                                But I can do it on Shift
                                Note that you can also press the Enter key to sample the material under the mouse
                                • kenK
                                  ken
                                  I have updated as required Fredo Tools to 1.1n and Thru:Paint to 1.0n, however the Check Plugin for Updates still list the two programs as Fredo Tools as 1.1m and Thru:Paint as 1.0m.
                                  Am I making a mistake, or is the new programs not registering correctly?
                                  Ken
                                  • OxerO
                                    Oxer
                                    Hi Fredo, i'm testing the last revision of ThruPaint 1.0n on Mac (OSX 10.6.8 & SU8) all works fine except that you say in the main post about Material Selector but i have found other problem the arrows don't work on Mac, it is not a big problem because i can introduce the values through the Measures or Visual Edition Mode.
                                    Thanks for this great plugin!! πŸ‘
                                    • fredo6F
                                      Oxer,
                                      Did it work in previous versions?
                                      Or other Mac OS versions?
                                      • OxerO
                                        Oxer
                                        Oxer,
                                        No, it doesn't work in previous version.
                                        I haven't probed other Mac OS versions.
                                        • P
                                          Pherim
                                          This is really great, thank you for fulfilling my request!
                                          It works great, just how I wanted it to. [[Just one small thing: It would be perfect to me if the "sample material" tool could also adopt the scale of the sampled material.
                                          I hope I don't bother you with my daydreams... πŸ˜’]] edit: never mind, it works perfectly! πŸ‘
                                          • fredo6F
                                            Oxer,
                                            Strange because it works for some other Mac users
                                            Could you type in the Ruby Console
                                            • VK_DOWN
                                            • VK_UP
                                            • VK_LEFT
                                            • VK_RIGHT
                                            • 16
                                            • 17
                                            • 4 / 17
