    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 526.1k Views 102 Watching
    • W Offline
      wolfy
      @wolfi,
      It might be a conflict with another plugin, which you would not have in the PC at the office.
      Do you have any plugins dealing with materials or UV mapping?
      For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
      Fredo,
      Entered your code into ruby console and it returned the following (sorry in advance for the length):
      dclone
      write_thumbnail
      profile_member?
      methods
      attribute_dictionaries
      get_attributes
      remove_observer
      instance_variable_defined?
      taint
      name
      name=
      id
      set_attribute
      singleton_methods
      respond_to?
      entityID
      nil?
      send
      protected_methods
      get_attribute
      tainted?
      display_name
      untaint
      instance_of?
      typename
      equal?
      method
      hash
      private_methods
      attribute_dictionary
      send
      materialType
      kind_of?
      freeze
      eql?
      object_id
      has_attributes?
      id
      public_methods
      instance_eval
      deleted?
      is_a?
      delete_attribute
      type
      valid?
      instance_variables
      use_alpha?
      frozen?
      alpha
      to_a
      alpha=
      class
      instance_variable_get
      between?
      parent
      color
      to_s
      extend
      color=
      clone
      instance_variable_set
      model
      texture
      inspect
      texture=
      display
      add_observer
      dup
        SpookyChick1013
        Thank You Fredo. This looks like the answer to many of my prayers. Looks like it shall be an interesting week, finally revising some old projects.
        https://kuromatsudriveyards.com
        Fo-su to tomo ni aran koto o...
          cmoreink
          Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him πŸ˜‰
          my portfolio
          • pep75P Offline
            pep75
            Jiiiiiihhhaaaaaaaaaaaaaaa!!!!!!! 😳
              Pherim
              Played around with it for quite some time now and still I am amazed about what this plugin can do.
              If I may ask, would it be possible to add an option that allows to chose the scale of the texture before applying it and then keep that value until it is changed? That would save a lot of time in comparison to changing the scale of each texture manually after it was applied.
              • fredo6F Offline
                That's a good idea, but I would put it as an option.
                Note you can also change the material definition (i.e. the dimensions).
                  Pherim
                  Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
                  • KrisidiousK Offline
                    Krisidious
                    Remembering of last scaling and rotation factors by material.
                    OH MY... AWESOMENESS....
                    By: Kristoff Rand
                      About the first option
                      Yet existing for a multiple selection with normal use of SU?
                        jorge2011
                        fredo, thank you very much for this new update.
                        A query. Is possible to copy the material properties (rotation, scale, etc ...) and paste those properties to other faces?
                        • EarthMoverE Offline
                          EarthMover
                          Great update Fredo! This was my only issue with the tool. Now it is perfection!
                          Content Creator at Skapeup
                          • fredo6F Offline
                            You have the transfer UV mode, which allows to substitute a texture by another without changing the UVs.
                            Otherwise, if the faces are adjacent to the painted faces, just click and drag to extend the painting.
                              If the mesh is made out of Quads you can use QuadFace Tools to copy and paste UV mapping.
                                jorge2011
                                thank you very much
                                  jorge2011
                                  can be applied a methodology similar to native sketchup materials, using the "Alt" to copy the properties of a material?
                                  • fredo6F Offline
                                    We cannot use ALT in scripts because when the key is UP it gives focus to the main Sketchup menu.
                                    But I can do it on Shift
                                    Note that you can also press the Enter key to sample the material under the mouse
                                    • kenK Offline
                                      ken
                                      I have updated as required Fredo Tools to 1.1n and Thru:Paint to 1.0n, however the Check Plugin for Updates still list the two programs as Fredo Tools as 1.1m and Thru:Paint as 1.0m.
                                      Am I making a mistake, or is the new programs not registering correctly?
                                      Ken
                                      • OxerO Offline
                                        Oxer
                                        Hi Fredo, i'm testing the last revision of ThruPaint 1.0n on Mac (OSX 10.6.8 & SU8) all works fine except that you say in the main post about Material Selector but i have found other problem the arrows don't work on Mac, it is not a big problem because i can introduce the values through the Measures or Visual Edition Mode.
                                        Thanks for this great plugin!! πŸ‘
                                        • fredo6F Offline
                                          Oxer,
                                          Did it work in previous versions?
                                          Or other Mac OS versions?
                                          • OxerO Offline
                                            Oxer
                                            Oxer,
                                            No, it doesn't work in previous version.
                                            I haven't probed other Mac OS versions.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
