    [Plugin] SketchUV - now free
    176 Posts 62 Posters 169.5k Views 62 Watching
      rv1974
      Whaat, this is amazing tool. Thank you!
      The only thing I could complain about are the shortcuts. My U,V and arrows keys set for other tools.
      Was it hard to make a temporary shortcuts override?
      • W Offline
        Whaat
        Thanks! Unfortunately, you can't override the shortcuts (AFAIK). Maybe I can come up with a solution in a future update...
        • fredo6F Offline
          Whaat,
          For info, I have logged a bug to Google on that, asking them to let all alpha characters be captured by the VCB after a valid character (digit, (, +, -, ...) is entered. They do it for some charcaters like 's', 'm', 'x', etc...
          Let's see if they listen or hear!
          • W Offline
            Whaat
            Whaat,
            Thanks Fredo!
            • McGyverM Offline
              McGyver
              Hi there, sorry to a bother...
              I just purchased and installed SketchUV and I can not find it anywhere in SU... No toolbar, no listing in the plugins menu.
              It has been placed correctly in the plugins folder as far as I can tell... Macintosh HD/Library/Application Support/Google Sketchup 6 /SketchUp/Plugins.
              I tried it in SU 6 and 8 and it does not show up.
              The downloaded file was SketchUV.rbz
              I have never installed a RBZ file so far, could this be a problem? Does this require a password or some other method of activation?
              Is this a PC only plugin?
              In case you need to know: 2 GHz Intel Core 2 Duo running OS 10.5.8
              Thank you for any assistance in this matter.
              Visit My ShareCG Freebie Gallery
              • Rich O BrienR Online
                Check the preferences panel for install extension
                Or rename .rbz to .zip and extract
                • W Offline
                  Whaat
                  Hello! I think you will find all of your answers in the manual:
                  http://dl.dropbox.com/u/22333105/SketchUV%20Tutorials/SketchUV%20Manual.pdf
                  Let me know if you need further assistance.
                  Thanks for purchasing!
                  • W Offline
                    Whaat
                    Absolutely no bother! We've all had those moments. RBZ is a still a very new thing.
                    • McGyverM Offline
                      McGyver
                      Thank you Whaat, you are VERY quick to respond!
                      Sorry to have bothered you...
                      Apparently I just had a "DOH!" Homer Simpson moment... The rb part of rbz threw me off and I thought it was a different version of .rb.... like .rbs.
                      I've actually had this problem before (and apparently totally erased it from my tiny memory)... I googled the problem right after the post and when I realized I've had this problem before, I wanted slap my brain... sorry to bother you.
                      I used stuffit expander and now I see the appropriate files.
                      Once again, thank you for the quick response.
                      Edited to add- Thank you Rich O'Brien too... I just noticed your reply!
                        You can use this utility to help you install plugins, either in RB, RBS, RBZ or ZIP format: http://forums.sketchucation.com/viewtopic.php?f=323&t=42315
                        • N Offline
                          nektares
                          You have no idea how happy i was when i saw this on my tablet. Rushed to my office and bought it right away.
                          I wated for this for ages, no joke. I have no words to describe how happy i am with this. Thanks!
                          in 3 mins i was already getting what i expected, between this and the two venti´s i drank today i´m sure i will not be able to sleep tonight. This is fantastic
                          first test
                          here´s a link to a higher res image of the quick Thea render test of the UV mapping.
                          http://i249.photobucket.com/albums/gg239/nektares/Sketchuvtest1.jpg
                          • W Offline
                            Whaat
                            Great to read your enthusiasm! Nice render! (Hope you got some sleep 😆 )
                            • HieruH Offline
                              Hieru
                              Really loving this plugin and what I can now do inside SU with UVs.
                              I do however have a small problem when it comes to exporting UVs for more complex shapes. I accidentally chose a project specific location for the exported OBJ file. Is there a way to reset this?
                              www.davidhier.co.uk
                                Plugins > SketchUV > Set Export Path
                                • HieruH Offline
                                  Hieru
                                  Doh!
                                  Thanks Rich 😳
                                  www.davidhier.co.uk
                                  • brodieB Offline
                                    brodie
                                    Great job Whaat. I've only used it a bit but the Loop tool alone is worth the cost of admission. I've tried some alternatives with no success.
                                    And the Tube mapping works brilliantly. Absolutely on my 'must have' list. As far as I can tell this pretty much solves SU's lack of UV functionality. And what's more, it seems to work in a very SU like way, very intuitive, just a couple buttons and pretty easy to figure out after skimming through the youtube tutorials.
                                    I can't recommend it highly enough. Let me know if you ever need a kidney.
                                    -Brodie
                                    • W Offline
                                      Whaat
                                      -Brodie
                                      Thanks Brodie, that made my day! 😄
                                        redlerred7
                                        @whaat said:
                                        Super impressive!!
                                        I have a question in regards to exporting a finished model (to OBJ or DAE)...
                                        With some plugins that allow you to modify, or reposition a texture, when the finished model is exported, multiple copies of the texture image are generated (or in some cases, copies of parts of the image)... does this occur with SketchUV?
                                        Thank you in advance for any info.
                                        Hi. Your question is answered in this tutorial:
                                        [flash=560,315:vj7sa93i]http://www.youtube.com/v/baQwxL6mgMQ[/flash:vj7sa93i]
                                        That saved my computer's life when it came to the number of files SU used the chuck at me when I exported
                                        • MasterhandM Offline
                                          Masterhand
                                          Hey guys, I'm new in participation but not in the forum, besides I like to follow the forum by the tremendous training has published its knowledge is almost unnecessary to ask.
                                          I do not possess a card or even payment method, not to mention that in my country 15 dollars (a price more than cheap), multiplies by 5.
                                          So the question is: is there any free alternative or method that allows me to export all the textures used as one as shown in the video?
                                            Well, there is the old UVTools 0.2 by Whaat: http://forums.sketchucation.com/viewtopic.php?t=23725
                                            Though, it is not by near as good as this one.
                                            • 3 / 9
