    [Plugin] SketchUV - now free
    176 Posts 62 Posters 175.8k Views 62 Watching
    • numbthumbN
      numbthumb
      A kind of magic I´m willing to learn.
      And how did you make your signature dissapear Gaieus? 😄
      Comfortably numb...
      • GaieusG
        @whaat said:
        ...The maps should transfer perfectly to Max as long as you first use the triangulation function prior to 3DS export...
        Well, I do not know about Max itself (although why would it be different) but have tried a couple of 3rd party apps and indeed, with triangulation on, it exports perfectly.
        And Dale, you need to make a new video for this feature. This one shows the UV maps a bit distorted but the plugin does not distort them (any longer). 👍
        [off:2c139be9]
        It's there...
        http://forums.sketchucation.com/ucp.php?i=profile&mode=signature[/off:2c139be9]
        • KrisidiousK
          Krisidious
          awesome... Thanks Whaat.
          By: Kristoff Rand
            jorge2011
            beautiful coincidence.
            This new plugin comes with excellent new fredo tool for manipulating textures
            [flash=853,505:2ik15ks3]http://www.youtube.com/v/l2QjLlUQVrY&fs=1[/flash:2ik15ks3]
            thank you very much whaat
              Very complementary! ☀
              • McGyverM
                McGyver
                Super impressive!!
                I have a question in regards to exporting a finished model (to OBJ or DAE)...
                With some plugins that allow you to modify, or reposition a texture, when the finished model is exported, multiple copies of the texture image are generated (or in some cases, copies of parts of the image)... does this occur with SketchUV?
                Thank you in advance for any info.
                Visit My ShareCG Freebie Gallery
                • W
                  Whaat
                  Super impressive!!
                  Hi. Your question is answered in this tutorial:
                  [flash=560,315:2f18ixq5]http://www.youtube.com/v/baQwxL6mgMQ[/flash:2f18ixq5]
                  • McGyverM
                    McGyver
                    That is great!! Thank you Whaat for replying so quickly and providing a link to the video! Once again another great plugin for SU! Thanks!... And THANKS for making it affordable for those of us on a budget!
                    • W
                      Whaat
                      I had a support question about how to map a curving deformed tube-like shape composed of triangles so I created a quick video showing how I would do it. (I could have saved some time by not exporting the cap faces but you get the idea)
                      [flash=560,315:9c6bzvk2]http://www.youtube.com/v/U-Gb1_Ibi0k[/flash:9c6bzvk2]
                        rv1974
                        Whaat, this is amazing tool. Thank you!
                        The only thing I could complain about are the shortcuts. My U,V and arrows keys set for other tools.
                        Was it hard to make a temporary shortcuts override?
                        • W
                          Whaat
                          Thanks! Unfortunately, you can't override the shortcuts (AFAIK). Maybe I can come up with a solution in a future update...
                          • fredo6F
                            Whaat,
                            For info, I have logged a bug to Google on that, asking them to let all alpha characters be captured by the VCB after a valid character (digit, (, +, -, ...) is entered. They do it for some charcaters like 's', 'm', 'x', etc...
                            Let's see if they listen or hear!
                            • W
                              Whaat
                              Whaat,
                              Thanks Fredo!
                              • McGyverM
                                McGyver
                                Hi there, sorry to a bother...
                                I just purchased and installed SketchUV and I can not find it anywhere in SU... No toolbar, no listing in the plugins menu.
                                It has been placed correctly in the plugins folder as far as I can tell... Macintosh HD/Library/Application Support/Google Sketchup 6 /SketchUp/Plugins.
                                I tried it in SU 6 and 8 and it does not show up.
                                The downloaded file was SketchUV.rbz
                                I have never installed a RBZ file so far, could this be a problem? Does this require a password or some other method of activation?
                                Is this a PC only plugin?
                                In case you need to know: 2 GHz Intel Core 2 Duo running OS 10.5.8
                                Thank you for any assistance in this matter.
                                  Check the preferences panel for install extension
                                  Or rename .rbz to .zip and extract
                                  • W
                                    Whaat
                                    Hello! I think you will find all of your answers in the manual:
                                    http://dl.dropbox.com/u/22333105/SketchUV%20Tutorials/SketchUV%20Manual.pdf
                                    Let me know if you need further assistance.
                                    Thanks for purchasing!
                                    • W
                                      Whaat
                                      Absolutely no bother! We've all had those moments. RBZ is a still a very new thing.
                                      • McGyverM
                                        McGyver
                                        Thank you Whaat, you are VERY quick to respond!
                                        Sorry to have bothered you...
                                        Apparently I just had a "DOH!" Homer Simpson moment... The rb part of rbz threw me off and I thought it was a different version of .rb.... like .rbs.
                                        I've actually had this problem before (and apparently totally erased it from my tiny memory)... I googled the problem right after the post and when I realized I've had this problem before, I wanted slap my brain... sorry to bother you.
                                        I used stuffit expander and now I see the appropriate files.
                                        Once again, thank you for the quick response.
                                        Edited to add- Thank you Rich O'Brien too... I just noticed your reply!
                                          You can use this utility to help you install plugins, either in RB, RBS, RBZ or ZIP format: http://forums.sketchucation.com/viewtopic.php?f=323&t=42315
                                          • N
                                            nektares
                                            You have no idea how happy i was when i saw this on my tablet. Rushed to my office and bought it right away.
                                            I wated for this for ages, no joke. I have no words to describe how happy i am with this. Thanks!
                                            in 3 mins i was already getting what i expected, between this and the two venti´s i drank today i´m sure i will not be able to sleep tonight. This is fantastic
                                            first test
                                            here´s a link to a higher res image of the quick Thea render test of the UV mapping.
                                            http://i249.photobucket.com/albums/gg239/nektares/Sketchuvtest1.jpg
                                            • 2 / 9
