    [Plugin] SketchUV - now free
    176 Posts 62 Posters 175.8k Views 62 Watching
    • fredo6F
      @whaat said:
      Thanks! Unfortunately, you can't override the shortcuts (AFAIK). Maybe I can come up with a solution in a future update...
      Whaat,
      For info, I have logged a bug to Google on that, asking them to let all alpha characters be captured by the VCB after a valid character (digit, (, +, -, ...) is entered. They do it for some charcaters like 's', 'm', 'x', etc...
      Let's see if they listen or hear!
      • W
        Whaat
        Whaat,
        Thanks Fredo!
        • McGyverM
          McGyver
          Hi there, sorry to a bother...
          I just purchased and installed SketchUV and I can not find it anywhere in SU... No toolbar, no listing in the plugins menu.
          It has been placed correctly in the plugins folder as far as I can tell... Macintosh HD/Library/Application Support/Google Sketchup 6 /SketchUp/Plugins.
          I tried it in SU 6 and 8 and it does not show up.
          The downloaded file was SketchUV.rbz
          I have never installed a RBZ file so far, could this be a problem? Does this require a password or some other method of activation?
          Is this a PC only plugin?
          In case you need to know: 2 GHz Intel Core 2 Duo running OS 10.5.8
          Thank you for any assistance in this matter.
          Visit My ShareCG Freebie Gallery
            Check the preferences panel for install extension
            Or rename .rbz to .zip and extract
            • W
              Whaat
              Hello! I think you will find all of your answers in the manual:
              http://dl.dropbox.com/u/22333105/SketchUV%20Tutorials/SketchUV%20Manual.pdf
              Let me know if you need further assistance.
              Thanks for purchasing!
              • W
                Whaat
                Absolutely no bother! We've all had those moments. RBZ is a still a very new thing.
                • McGyverM
                  McGyver
                  Thank you Whaat, you are VERY quick to respond!
                  Sorry to have bothered you...
                  Apparently I just had a "DOH!" Homer Simpson moment... The rb part of rbz threw me off and I thought it was a different version of .rb.... like .rbs.
                  I've actually had this problem before (and apparently totally erased it from my tiny memory)... I googled the problem right after the post and when I realized I've had this problem before, I wanted slap my brain... sorry to bother you.
                  I used stuffit expander and now I see the appropriate files.
                  Once again, thank you for the quick response.
                  Edited to add- Thank you Rich O'Brien too... I just noticed your reply!
                    You can use this utility to help you install plugins, either in RB, RBS, RBZ or ZIP format: http://forums.sketchucation.com/viewtopic.php?f=323&t=42315
                    • N
                      nektares
                      You have no idea how happy i was when i saw this on my tablet. Rushed to my office and bought it right away.
                      I wated for this for ages, no joke. I have no words to describe how happy i am with this. Thanks!
                      in 3 mins i was already getting what i expected, between this and the two venti´s i drank today i´m sure i will not be able to sleep tonight. This is fantastic
                      first test
                      here´s a link to a higher res image of the quick Thea render test of the UV mapping.
                      http://i249.photobucket.com/albums/gg239/nektares/Sketchuvtest1.jpg
                      • W
                        Whaat
                        Great to read your enthusiasm! Nice render! (Hope you got some sleep 😆 )
                        • HieruH
                          Hieru
                          Really loving this plugin and what I can now do inside SU with UVs.
                          I do however have a small problem when it comes to exporting UVs for more complex shapes. I accidentally chose a project specific location for the exported OBJ file. Is there a way to reset this?
                          www.davidhier.co.uk
                            Plugins > SketchUV > Set Export Path
                            • HieruH
                              Hieru
                              Doh!
                              Thanks Rich 😳
                              www.davidhier.co.uk
                              • brodieB
                                brodie
                                Great job Whaat. I've only used it a bit but the Loop tool alone is worth the cost of admission. I've tried some alternatives with no success.
                                And the Tube mapping works brilliantly. Absolutely on my 'must have' list. As far as I can tell this pretty much solves SU's lack of UV functionality. And what's more, it seems to work in a very SU like way, very intuitive, just a couple buttons and pretty easy to figure out after skimming through the youtube tutorials.
                                I can't recommend it highly enough. Let me know if you ever need a kidney.
                                -Brodie
                                • W
                                  Whaat
                                  -Brodie
                                  Thanks Brodie, that made my day! 😄
                                    redlerred7
                                    @whaat said:
                                    Super impressive!!
                                    I have a question in regards to exporting a finished model (to OBJ or DAE)...
                                    With some plugins that allow you to modify, or reposition a texture, when the finished model is exported, multiple copies of the texture image are generated (or in some cases, copies of parts of the image)... does this occur with SketchUV?
                                    Thank you in advance for any info.
                                    Hi. Your question is answered in this tutorial:
                                    [flash=560,315:vj7sa93i]http://www.youtube.com/v/baQwxL6mgMQ[/flash:vj7sa93i]
                                    That saved my computer's life when it came to the number of files SU used the chuck at me when I exported
                                    • MasterhandM
                                      Masterhand
                                      Hey guys, I'm new in participation but not in the forum, besides I like to follow the forum by the tremendous training has published its knowledge is almost unnecessary to ask.
                                      I do not possess a card or even payment method, not to mention that in my country 15 dollars (a price more than cheap), multiplies by 5.
                                      So the question is: is there any free alternative or method that allows me to export all the textures used as one as shown in the video?
                                        Well, there is the old UVTools 0.2 by Whaat: http://forums.sketchucation.com/viewtopic.php?t=23725
                                        Though, it is not by near as good as this one.
                                        • MasterhandM
                                          Masterhand
                                          Thom thank you very much for the quick reply, I have lowered that UVTools but has no option to export the texture as one.
                                          Is there a procedure I am ignorant to do so? or UVtools.rb which one should I download?
                                            There is not a plugin which exports all mapped textures in a model to one texture file.
                                            Ultimate Unwrap 3D can do this with imported .skp files but I haven't tried it yet. It's also about $50 so more expensive than this plugin.
                                            • 3 / 9
