    [Plugin] SplitUp
    38 Posts 20 Posters 83.9k Views 20 Watching
    • Rich O BrienR Online
      Here's a tool you might find useful for displacement.
      [flash=600,338:37mvwqrx]http://www.youtube.com/v/ggP__N-8Sg4[/flash:37mvwqrx]
      (c) TIG 2011-2016
      Usage:
      Splits selected 'quad faces' into the specified number of parts.
      Use in Ruby Console or other code, thus:
      SplitUp.new(2) [or more sloppily SplitUp.new 2]
      as shown here 2 is the number of divisions wanted.
      OR use Tools > Split Tools... > submenu item SplitUp and enter the
      division number in the dialog [default=1 >> NO splits]
      [The Plugins menu item is now disabled by default from v1.5 but see end
      of the main code IF you want to re-enable it...]
      If any selected face is not a quad OR a quad with one quad-hole - then the face and probably all of its connected neighbours should first be 'Quadrilateralized' - i.e. split up into quads - a message tells you this, but you may still continue...
      New edges are softened/smoothed.
      It returns the number of faces processed and made [n,nn]
      It's one step undoable.
      Donations:
      By PayPal.com to info @ revitrev.org
      Version:
      1.0 20110717 First issue. [Alpha]
      1.1 20110718 Now works on quads and quads with one quad hole. Plugins menu item and dialog added.
      1.2 20110718 Softened/smoothed new edges.
      1.3 20110719 Glitches with smoothing etc fixed.
      1.4 20111111 Overhauled and less error prone.
      1.5 20120219 Plugins menu item disabled; now in Tools > Split Tools submenu.
      2.0 20160818 Now comes within the SplitTOOLS RBZ, do not install separately. Signed for v2016
      http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
        Thanks to TIG for the code. I only bugged him to make it happen πŸ˜’
          driven
          Excellento...
          I've been waiting for this one, cheers to bringing it to fruition. [and/or bugging TIG]
            ktslambieng
            woa... thank u verry much.
            I have found,
            I asked,
            I have now found
            • massimoM Offline
              massimo Moderator
              Thanks Rich&TIG. πŸ‘ Will test it.
              • N Offline
                numerobis
                πŸ‘ looks VERY useful! Thanks! 😎
                • andybotA Offline
                  andybot
                  THANK YOU!!! I've been doing this manually for the longest time. This is perfect!!!
                    JGA
                    Thanks for sharing the ruby & providing the clear video, but can I ask what this would be used for?
                    I thought the mantra for SKUP was to minimise the numbers of edges & faces.
                    Regards,
                    JGA
                    • massimoM Offline
                      massimo Moderator
                      From Rich's first post...
                      πŸ˜„
                        You could also use it for crosswords or sudoku. It has a myriad of uses πŸ‘
                        • massimoM Offline
                          massimo Moderator
                            JGA
                            Still none the wiser though...
                            Regards,
                            JGA
                            • massimoM Offline
                              massimo Moderator
                              Well JGA it's useful if you want to subdivide a surface in order to use it in a rendering software which supports displacement. πŸ˜‰
                                ...and displacement is like bumps on steroids.
                                • TIGT Online
                                  I know nothing...
                                  I was only acting on orders.
                                  • massimoM Offline
                                    massimo Moderator
                                    πŸ˜†
                                      He's been a good pupil. Bit cranky but certainly has potential. πŸ‘
                                      • F Offline
                                        Fletch
                                        Very nice, thank you gentlemen!
                                        Fletch
                                        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                          Panga
                                          Thanks a lot for this one !!! πŸ‘
                                          • simon le bonS Offline
                                            simon le bon
                                            Hi Rich and all,
                                            Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot πŸ˜‰ )
                                            Concerning SplitUp, I am in limbo πŸ˜•
                                            I know what is a displacement map but I can't figure out how SplitUp can help 😳
                                            Could you give the idea ?
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
                                            Cheers,
                                            Simon
