    [req] a good stairmaking plugin
    25 Posts 12 Posters 2.6k Views 12 Watching
    • sdmitchS Offline
      sdmitch
      Something like this Rock?
      Stairs
      http://sdmitch.blogspot.com/
      • jarynzlesaJ Offline
        jarynzlesa
        @rock1 said:
        is there a good free plugin that can make open well staircases, u shaped staircases?
        No.
        http://www.vizualizaceschodiste.mypage.cz/
          rock1
          @tig said:
          Somethings are just quicker 'by hand' - how hard can it be?
          This took < 5 minutes with NO Plugins, watching the TV and eating my tea ![attachment=0:1ujghkor]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1ujghkor]
          wow!! πŸ‘ video tutorial please πŸ˜„
          Signature removed by SCF Admin
            rock1
            hey how did you make them!! I wanna know
            • bac9-flclB Offline
              bac9-flcl
              http://sketchup.google.com/intl/en/training/videos/new_to_gsu.html
              http://sketchup.google.com/intl/en/training/videos/familiar_with_gsu.html
              Have you studied these? "Copy and Arrays" tutorial in particular.
              There is nothing complicated in there. ))
              • EdsonE Offline
                Edson
                the sketchup show #38 part 1 and part 2.
                http://www.mahfuz.arq.br
                • sdmitchS Offline
                  sdmitch
                  rock, with a plugin of my own. I did cheat a little on the u-shaped 12,3,12 set. I created a run of 12 then copied,rotated and moved it into position. The run of 3 was then rotated and moved into place. The elliptical stairs required nothing additional to be done. The plugin has a u-shape option but it assumes stair runs stop and start at a landing.
                    rock1
                    well which plugin r u using? πŸ˜›
                    • sdmitchS Offline
                      sdmitch
                        rock1
                        @sdmitch said:
                        don't mind but can you upload here? πŸ˜’
                          I expect he would have uploaded it here already if he'd been interested in sharing with you.
                          • sdmitchS Offline
                            sdmitch
                            Well Dave he never asked for it, only about it, so I fealt no compulsion the give it.
                            Rock, the plugin in question is attached. You can access it through the Plugins menu. There are 3 options, Normal, Spiral, and U-Shape.
                            Normal is just a straight run with a railing on one side. The steps are a group and the rail is a group.
                            Spiral is a circular or elliptical stair depending on the Max,Min width input. It is a single group.
                            U-Shape now accepts "turn steps" which replace the landing if defined. This is a single group also.
                            Stair Maker
                              rock1
                              πŸ˜„ that's so kind of you , thanks a lot people like sdmitch are men of honour. Look fellas, these are men of honour, these are men of honour!! πŸ‘
                              • utilerU Offline
                                utiler
                                G'day Sam, nice little plugin!
                                I have some ideas for you to add if you could to extend it a little more.... see attached PDF.
                                stairMaker.pdf
                                Just Curious...
                                • charly2008C Offline
                                  charly2008
                                  Thank you very much Sam,
                                  a very useful and time saving plugin.
                                  Charly
                                  • sdmitchS Offline
                                    sdmitch
                                    Andrew, I will take a look at your suggestion and see what I can do. Some are trivial like asking for and using a given gap between the runs and the height and offset for the handrail. The "in-situ" option not so trivial but I'll see what I can do.
                                    • utilerU Offline
                                      utiler
                                      Thanks Sam, appreciate it!
                                      Also for your u-shape stair maybe add a tread thickness and make treads components... Just helps with edits.
                                      Well done, mate! simple and very effective tool!
                                      Just Curious...
                                      • sdmitchS Offline
                                        sdmitch
                                        Andrew, I think I have incorporated all the changes you suggested except make the treads components. Maybe in version 3.
                                        Stair Maker
