    [req] a good stairmaking plugin
    25 Posts 12 Posters 2.6k Views 12 Watching
      Why don't you just draw them? You'd have them done by now.
        Somethings are just quicker 'by hand' - how hard can it be?
        This took < 5 minutes with NO Plugins, watching the TV and eating my tea !Capture.PNG
          http://www.gifs.net/Animation11/Hobbies_and_Entertainment/Fishing/Flyfishing.gif
          • sdmitchS Offline
            sdmitch
            Something like this Rock?
            Stairs
            http://sdmitch.blogspot.com/
            • jarynzlesaJ Offline
              jarynzlesa
              @rock1 said:
              is there a good free plugin that can make open well staircases, u shaped staircases?
              No.
              http://www.vizualizaceschodiste.mypage.cz/
                rock1
                This took < 5 minutes with NO Plugins, watching the TV and eating my tea ![attachment=0:1ujghkor]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1ujghkor]
                wow!! πŸ‘ video tutorial please πŸ˜„
                Signature removed by SCF Admin
                  rock1
                  hey how did you make them!! I wanna know
                  • bac9-flclB Offline
                    bac9-flcl
                    http://sketchup.google.com/intl/en/training/videos/new_to_gsu.html
                    http://sketchup.google.com/intl/en/training/videos/familiar_with_gsu.html
                    Have you studied these? "Copy and Arrays" tutorial in particular.
                    There is nothing complicated in there. ))
                    • EdsonE Offline
                      Edson
                      the sketchup show #38 part 1 and part 2.
                      http://www.mahfuz.arq.br
                      • sdmitchS Offline
                        sdmitch
                        rock, with a plugin of my own. I did cheat a little on the u-shaped 12,3,12 set. I created a run of 12 then copied,rotated and moved it into position. The run of 3 was then rotated and moved into place. The elliptical stairs required nothing additional to be done. The plugin has a u-shape option but it assumes stair runs stop and start at a landing.
                          rock1
                          well which plugin r u using? πŸ˜›
                          • sdmitchS Offline
                            sdmitch
                              rock1
                              @sdmitch said:
                              don't mind but can you upload here? πŸ˜’
                                I expect he would have uploaded it here already if he'd been interested in sharing with you.
                                • sdmitchS Offline
                                  sdmitch
                                  Well Dave he never asked for it, only about it, so I fealt no compulsion the give it.
                                  Rock, the plugin in question is attached. You can access it through the Plugins menu. There are 3 options, Normal, Spiral, and U-Shape.
                                  Normal is just a straight run with a railing on one side. The steps are a group and the rail is a group.
                                  Spiral is a circular or elliptical stair depending on the Max,Min width input. It is a single group.
                                  U-Shape now accepts "turn steps" which replace the landing if defined. This is a single group also.
                                  Stair Maker
                                    rock1
                                    πŸ˜„ that's so kind of you , thanks a lot people like sdmitch are men of honour. Look fellas, these are men of honour, these are men of honour!! πŸ‘
                                    • utilerU Offline
                                      utiler
                                      G'day Sam, nice little plugin!
                                      I have some ideas for you to add if you could to extend it a little more.... see attached PDF.
                                      stairMaker.pdf
                                      Just Curious...
                                      • charly2008C Offline
                                        charly2008
                                        Thank you very much Sam,
                                        a very useful and time saving plugin.
                                        Charly
                                        • sdmitchS Offline
                                          sdmitch
                                          Andrew, I will take a look at your suggestion and see what I can do. Some are trivial like asking for and using a given gap between the runs and the height and offset for the handrail. The "in-situ" option not so trivial but I'll see what I can do.
                                          • utilerU Offline
                                            utiler
                                            Thanks Sam, appreciate it!
                                            Also for your u-shape stair maybe add a tread thickness and make treads components... Just helps with edits.
                                            Well done, mate! simple and very effective tool!
                                            Just Curious...
