    [req] a good stairmaking plugin
    25 Posts 12 Posters 3.1k Views 12 Watching
      rock1
      @tig said:
      Somethings are just quicker 'by hand' - how hard can it be?
      This took < 5 minutes with NO Plugins, watching the TV and eating my tea ![attachment=0:1ujghkor]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1ujghkor]
      wow!! πŸ‘ video tutorial please πŸ˜„
      Signature removed by SCF Admin
        rock1
        @sdmitch said:
        Something like this Rock?
        hey how did you make them!! I wanna know
        • bac9-flclB
          bac9-flcl
          http://sketchup.google.com/intl/en/training/videos/new_to_gsu.html
          http://sketchup.google.com/intl/en/training/videos/familiar_with_gsu.html
          Have you studied these? "Copy and Arrays" tutorial in particular.
          There is nothing complicated in there. ))
          • EdsonE
            Edson
            the sketchup show #38 part 1 and part 2.
            http://www.mahfuz.arq.br
            • sdmitchS
              sdmitch
              rock, with a plugin of my own. I did cheat a little on the u-shaped 12,3,12 set. I created a run of 12 then copied,rotated and moved it into position. The run of 3 was then rotated and moved into place. The elliptical stairs required nothing additional to be done. The plugin has a u-shape option but it assumes stair runs stop and start at a landing.
              http://sdmitch.blogspot.com/
                rock1
                well which plugin r u using? πŸ˜›
                • sdmitchS
                  sdmitch
                    rock1
                    @sdmitch said:
                    don't mind but can you upload here? πŸ˜’
                      I expect he would have uploaded it here already if he'd been interested in sharing with you.
                      • sdmitchS
                        sdmitch
                        Well Dave he never asked for it, only about it, so I fealt no compulsion the give it.
                        Rock, the plugin in question is attached. You can access it through the Plugins menu. There are 3 options, Normal, Spiral, and U-Shape.
                        Normal is just a straight run with a railing on one side. The steps are a group and the rail is a group.
                        Spiral is a circular or elliptical stair depending on the Max,Min width input. It is a single group.
                        U-Shape now accepts "turn steps" which replace the landing if defined. This is a single group also.
                        Stair Maker
                          rock1
                          πŸ˜„ that's so kind of you , thanks a lot people like sdmitch are men of honour. Look fellas, these are men of honour, these are men of honour!! πŸ‘
                          • utilerU
                            utiler
                            G'day Sam, nice little plugin!
                            I have some ideas for you to add if you could to extend it a little more.... see attached PDF.
                            stairMaker.pdf
                            Just Curious...
                            • charly2008C
                              charly2008
                              Thank you very much Sam,
                              a very useful and time saving plugin.
                              Charly
                              • sdmitchS
                                sdmitch
                                Andrew, I will take a look at your suggestion and see what I can do. Some are trivial like asking for and using a given gap between the runs and the height and offset for the handrail. The "in-situ" option not so trivial but I'll see what I can do.
                                • utilerU
                                  utiler
                                  Thanks Sam, appreciate it!
                                  Also for your u-shape stair maybe add a tread thickness and make treads components... Just helps with edits.
                                  Well done, mate! simple and very effective tool!
                                  Just Curious...
                                  • sdmitchS
                                    sdmitch
                                    Andrew, I think I have incorporated all the changes you suggested except make the treads components. Maybe in version 3.
                                    Stair Maker
