[req] a good stairmaking plugin
is there a good free plugin that can make open well staircases, u shaped staircases?
Her is a good stair maker (http://www.1001bit.com/products/staircase2.shtml) , it's not free but if you are a student you can have an academic licence, you can give it a try you can do other stuff all so with this script, i hope it helped.
This may be of use for your purposes:
http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
Very simple to use
Hope this helps
Howard L' -
eh, actually i need a plugin that makes 3 flight staircase. in one flight there are 12 steps, in another 3 steps, in the next one 12 steps again. I also need a plugin that creates elliptical staircases.
Why don't you just draw them? You'd have them done by now.
Somethings are just quicker 'by hand' - how hard can it be?
This took < 5 minutes with NO Plugins, watching the TV and eating my tea ! -
No.
This took < 5 minutes with NO Plugins, watching the TV and eating my tea ![attachment=0:1ujghkor]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1ujghkor]wow!!
video tutorial please
@rock1 said:
@sdmitch said:
Something like this Rock?
hey how did you make them!! I wanna know
http://sketchup.google.com/intl/en/training/videos/new_to_gsu.html
http://sketchup.google.com/intl/en/training/videos/familiar_with_gsu.htmlHave you studied these? "Copy and Arrays" tutorial in particular.
There is nothing complicated in there. )) -
rock, with a plugin of my own. I did cheat a little on the u-shaped 12,3,12 set. I created a run of 12 then copied,rotated and moved it into position. The run of 3 was then rotated and moved into place. The elliptical stairs required nothing additional to be done. The plugin has a u-shape option but it assumes stair runs stop and start at a landing.
well which plugin r u using?
@sdmitch said:
don't mind but can you upload here?
I expect he would have uploaded it here already if he'd been interested in sharing with you.
Well Dave he never asked for it, only about it, so I fealt no compulsion the give it.
Rock, the plugin in question is attached. You can access it through the Plugins menu. There are 3 options, Normal, Spiral, and U-Shape.
Normal is just a straight run with a railing on one side. The steps are a group and the rail is a group.
Spiral is a circular or elliptical stair depending on the Max,Min width input. It is a single group.
U-Shape now accepts "turn steps" which replace the landing if defined. This is a single group also.
that's so kind of you , thanks a lot people like sdmitch are men of honour. Look fellas, these are men of honour, these are men of honour!!
