    [Plugin] Edge Tools
    211 Posts 74 Posters 316.8k Views 74 Watching
      πŸ‘
      Thanks Thom
        That one was for you Rich! πŸ˜‰
          You've moved up in my favourite person list. Your now 82nd πŸ‘
          • EdsonE Offline
            Edson
            thom,
            I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
            http://www.mahfuz.arq.br
              hmm... no tooltips...? how odd...
              and you get it on other plugins`?
              I don't see why there should be a difference for OSX on this... πŸ˜•
              • EdsonE Offline
                Edson
                I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
                • wind-borneW Offline
                  wind-borne
                  @edson said:
                  thom,
                  I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical.
                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                  %(#BF80BF)[SU 8 pro
                  • EdsonE Offline
                    Edson
                    not so in mine. no feedback either way.
                    • jeff hammondJ Offline
                      position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work.
                        eh? Is this a know OSX issue?
                        what an bizzare one... πŸ˜• πŸ˜’
                        • EdsonE Offline
                          Edson
                          bizarre indeed! the tooltips are working now! and what a useful plugin this is! πŸ‘ thanks for it, thom.
                            it's hard to say since sketchup is the only app i use that allows you to drag a toolbar to the top of the screen and it will switch to horizontal orientation.
                            it's very weird toolbar behavior in OSX world so i doubt it's a known issue since no apps do it.
                            i just stumbled upon it one day when i tried 1001bit toolbar across the top of my screen.
                            (bonzai has a few horizontal toolbars but their tooltips (vert&horizontal) aren't standard so they've done something to modify the icons/tooltips)
                            • N Offline
                              nicasiojoel
                              Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
                                2.0.4 - 11.07.2011
                                • Close All Edge Gaps: Heals closed edges.
                                • Close All Edge Gaps: Undoable.
                                • Close All Edge Gaps: Inputbox store values correctly.
                                  πŸ‘
                                  • EarthMoverE Offline
                                    EarthMover
                                    Nice update. Thanks Thomthom!! πŸ‘
                                    Content Creator at Skapeup
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi, ThomThom:
                                      Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post?
                                        hm.. was just a minor update, really needed?
                                          MartinK
                                          Thanks for the plugin. I'm getting ready to try the simplify curves routine on a large number of contours. As always, these plugins you and others generously make available are great time savers, and I appreciate your efforts. Thanks again. πŸ‘
                                          • xiombargX Offline
                                            xiombarg
                                            Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
                                            • 11
                                            • 6 / 11
