    [Plugin] Edge Tools
    211 Posts 74 Posters 310.9k Views 74 Watching
    • EarthMoverE Offline
      EarthMover
      No worries bro. Just a thought for the next update whenever you get around to it.
      Content Creator at Skapeup
      • H Offline
        harnstein
        Just wanted to say thanks! Comes in very handy!
        Great work you're doing, man ๐Ÿ˜„
        still sketchin'
          rock1
          wow!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ Truly out of the world. The most useful one I found was that this plugin automatically detects edges and heals them ๐Ÿ˜ . Thanks a lot thomthom!!
          Signature removed by SCF Admin
          • Rich O BrienR Online
            Thom,
            when using 'split faces into multiple' then inputting an array only # works (not #). Not a major thing but thought you'd like to know.
            It's the same for #/
              Thom,
              hmm... never knew that was a input format. That shouldn't be too hard to add.
                Strange thing is I never knew the other method of input until I used this tool.
                Anyway it's no biggie as I'm sure you're up to your eyes as it is.
                  I've had an update lingering for this anyway (small compatibility fix). So I need to get it out anyway.
                    kizner
                    THANK A LOT - I WAS LOOKING FOR YOUR PLUGINS- THIS IS MUST HAVE IN ALL SKP.
                    EVERY BODY SHOULD TRY
                      # 2.0.3 - 10.05.2011
                      #		 * VCB input now accepts all array format variants.
                      #		 * Fixed namespace compatibility with TT_Lib 2.5.4
                      Requires TT_Lib 2.5.4
                        ๐Ÿ‘
                        Thanks Thom
                          That one was for you Rich! ๐Ÿ˜‰
                            You've moved up in my favourite person list. Your now 82nd ๐Ÿ‘
                            • EdsonE Offline
                              Edson
                              thom,
                              I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
                              edson mahfuz, architect| porto alegre โ€ข brasil
                              http://www.mahfuz.arq.br
                                hmm... no tooltips...? how odd...
                                and you get it on other plugins`?
                                I don't see why there should be a difference for OSX on this... ๐Ÿ˜•
                                • EdsonE Offline
                                  Edson
                                  I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
                                  • wind-borneW Offline
                                    wind-borne
                                    @edson said:
                                    thom,
                                    I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical.
                                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                                    %(#BF80BF)[SU 8 pro
                                    • EdsonE Offline
                                      Edson
                                      not so in mine. no feedback either way.
                                      • jeff hammondJ Offline
                                        position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work.
                                          eh? Is this a know OSX issue?
                                          what an bizzare one... ๐Ÿ˜• ๐Ÿ˜’
                                          • EdsonE Offline
                                            Edson
                                            bizarre indeed! the tooltips are working now! and what a useful plugin this is! ๐Ÿ‘ thanks for it, thom.
                                            • 11
                                            • 6 / 11
